PPPoE and Transparent bridge
I am trying to run pppoe server on mikrotik with two bridged interfaces (WAN , LAN) with gateway upstream.
pool 10.0.0.100 -10.0.0.254
upstream gateway 10.0.0.1
Do I have to make any changes to ppp / pppoe-server server to make this work with the bridged interfaces?
Thanks,
None I can think of. The PPPoE server can be bound to one interface - LAN. PPPoE packets can be filtered in firewall if needed. You can read about Bridge here: http://www.mikrotik.com/testdocs/ros/2.9/interface/bridge.php I think you should filter PPPoE packets so that they do not go upstream and also use additional filtering to protect the upstream link from junk/unwanted traffic.
