PPPoE "authentication interval"
Is there a way for an active pppoe connection to be checked for authorization at a specified time interval?
Example,
I connect with my pppoe client, 10 minutes later my account is disabled. I am still connected since I was previously authenticated.
I would like to implement a “re-authentication” interval to check every x minutes to make sure I am still authorized to access the network.
Is this possible?
Thanks,
http://www.mikrotik.com/testdocs/ros/2.9/guide/aaa_radius_content.php#.3
Can you pont me in a more specific direction? Do I need to look at the “Disconnect-Messages” portion?
Does this feature require additional configuration of my radius server?
Thanks,
it is link on ‘Connection Terminating from RADIUS’ section
look at ‘dialup.radkill’ (FreeRADIUS?) script
