how can I limit bandwidth in PPP profiles? I found “Rate Limit (rx/tx)” but it didn’t work, what value should I add in this field?
thanks
thanks
should i ask what values u add? ppp profile menu has the tx-bit-rate and rx-bit-rate values, so add values u need for each pppoe client. By default there is bps (bits per second) if u wanna give ppp client 1Mbps on Tx/Rx set it to 1M Tx Rate and 1M Rx rate.
