Hello - hopefully a straight forward one…
We have several relay sites that have wireless access points with CPE connected.
Some of the CPE (but not all) want a static IP.
I am doing this with PPPoE and running PPPoE at each relay rather than centrally (I have reasons for doing it like this).
I have a /25 public IP range that I wish to use as sparingly as possible. As some sites might only need 1 or 2 CPE with public IPs, how is best to achieve this without wasting public IPs on subnet’s that are larger than what I need?
At the moment, I give clients a static IP per ppp secret rather than using a pool as that works well for a per user basis of public IPs.
/ppp secret add local-address=1XX.XXX.XXX.112 name=user1@relay1 password=somepassword
profile=My-Standard remote-address=1XX.XXX.XXX.113
/interface pppoe-server server
add default-profile=My-Standard disabled=no interface=My-PPPoE max-mru=
1492 max-mtu=1492 mrru=1600 service-name=MyService
The main bit I’m struggling with is the use of the local-address . I can give remote address (what the client gets) as a /32 and that’s efficient. If each PPPoE needs a local-address, that’s fine, I just want confirmation that it is the case or if there’s a better way of doing things.
Do I need to use a local-address on each site so there is some reference on the router to the public IP or can I drop this and just a /32 on the PPPoE remote address and leave it at that?
Any points would be appreciated.
MM99
Just make PPPoE server assign them to the customers as the remote PTP end. I assume you’re running OSPF between all relays and provider edge router.
Local address is only used by the relay and customer pppoe end. No, it hasn’t to be different, usual practice is using the same one (usually on a loopback device) used for router ID for all PPPoE users.
You can use any IP though.
Hi Pukkita,
Thanks for the info.
Yes, we run OSPF between all relay sites.
So I could just pick one of my public IP addresses and use this as the “local-address” on all the PPPoE servers at each relay? The local-adderss doesn’t actually serve any routing function?
Thanks for the quick reply.
MM99
No, not for the local address, but for remote-address of the specific customer needing it. Local address should/could be the same for all pppoe users on a given router, and it’s usually a private one as it won’t be using by anything else than local traffic between its pppoe users and the router.
OK great. That clears it up for me.
