Hope this helps
/ ip address
add address=192.168.0.1/24 interface=LAN
add address=192.168.1.2/24 interface=WAN1
add address=192.168.2.2/24 interface=WAN2
add address=192.168.3.2/24 interface=WAN3
add address=192.168.4.2/24 interface=WAN4
/ ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=LAN
add chain=prerouting in-interface=WAN1 connection-mark=no-mark action=mark-connection \ new-connection-mark=WAN1_conn
add chain=prerouting in-interface=WAN2 connection-mark=no-mark action=mark-connection \ new-connection-mark=WAN2_conn
add chain=prerouting in-interface=WAN3 connection-mark=no-mark action=mark-connection \ new-connection-mark=WAN3_conn
add chain=prerouting in-interface=WAN4 connection-mark=no-mark action=mark-connection \ new-connection-mark=WAN4_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \ per-connection-classifier=both-addresses-and-ports:4/0 action=mark-connection new-connection-mark=WAN1_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \ per-connection-classifier=both-addresses-and-ports:4/1 action=mark-connection new-connection-mark=WAN2_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \ per-connection-classifier=both-addresses-and-ports:4/2 action=mark-connection new-connection-mark=WAN3_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \ per-connection-classifier=both-addresses-and-ports:4/3 action=mark-connection new-connection-mark=WAN4_conn
add chain=prerouting connection-mark=WAN1_conn in-interface=LAN action=mark-routing \ new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=LAN action=mark-routing \ new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=LAN action=mark-routing \ new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN4_conn in-interface=LAN action=mark-routing \ new-routing-mark=to_WAN4
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=4 check-gateway=ping
add dst-address=208.67.222.222 gateway=192.168.1.1 scope=10
add dst-address=208.67.220.220 gateway=192.168.1.1 scope=10
add dst-address=208.67.222.222 gateway=192.168.2.1 scope=10
add dst-address=208.67.220.220 gateway=192.168.2.1 scope=10
add dst-address=208.67.222.222 gateway=192.168.3.1 scope=10
add dst-address=208.67.220.220 gateway=192.168.3.1 scope=10
add dst-address=208.67.222.222 gateway=192.168.4.1 scope=10
add dst-address=208.67.220.220 gateway=192.168.4.1 scope=10
add distance=1 gateway=208.67.222.222 routing-mark=to_WAN1 check-gateway=ping
add distance=2 gateway=208.67.220.220 routing-mark=to_WAN1 check-gateway=ping
add distance=1 gateway=208.67.222.222 routing-mark=to_WAN2 check-gateway=ping
add distance=2 gateway=208.67.220.220 routing-mark=to_WAN2 check-gateway=ping
add distance=1 gateway=208.67.222.222 routing-mark=to_WAN3 check-gateway=ping
add distance=2 gateway=208.67.220.220 routing-mark=to_WAN3 check-gateway=ping
add distance=1 gateway=208.67.222.222 routing-mark=to_WAN4 check-gateway=ping
add distance=2 gateway=208.67.220.220 routing-mark=to_WAN4 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade
