i have setup a RB450G with PPPoE client, nat and switched ports.
It looks like, after the router is rebooted, the lan interface is not brought up, no commands work on the CLI such as "interface print" or "ip address print" nor the switch ports work.
Using 4.2, but same problem was on 4.1.
After couple of reboots, everything works as expected, but this is a problem if doing remote updates or reboots.
I have noticed that this problem occurs only when the PPPoE client is enabled and configured. Thing is i cannot disable the client since the CLI does not respond to any commands, whenever i issue something it just hangs and if i press CTRL+C it goes back to the CLI with nothing being displayed, except for the table headers:
[admin@kick-home] > interface print
NAME TYPE MTU L2MTU
[admin@kick-home] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
[admin@kick-home] > interface ppp-client print
[admin@kick-home] >
Any thoughts ?
Thanks,
Viorel
