I have a Mikrotik hap ac2 with RouterOS 6.44.1 installed. I use it along with my Belkin ADSL modem-router that is set in bridge mode (acting only as modem, not as router). Internally, it is called as 1483 bridge mode within the modem-router. I use Mikrotik router as pppoe-client to connect to the internet and it acts as router to connect the other devices with internet.
Everything used to work until a couple of days ago. I don’t remember changing any configuration on the previous day/s. But, I do remember that I updated the RouterOS recently from 6.43.x to 6.44.x a few days ago. I keep my internet on 24x7. Anyway, I can’t use Mikrotik router as pppoe-client, anymore. Here’s the debug log from RouterOS…
12:54:30 pppoe,ppp,info pppoe-out1-bsnl-adsl: initializing...
12:54:30 pppoe,ppp,info pppoe-out1-bsnl-adsl: connecting...
12:54:30 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:30 pppoe,debug,packet session-id=0x0000
12:54:30 pppoe,debug,packet host-uniq=0x9400b600
12:54:30 pppoe,debug,packet service-name=BSNL ADSL
12:54:31 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:31 pppoe,debug,packet session-id=0x0000
12:54:31 pppoe,debug,packet host-uniq=0x9400b600
12:54:31 pppoe,debug,packet service-name=BSNL ADSL
12:54:32 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:32 pppoe,debug,packet session-id=0x0000
12:54:32 pppoe,debug,packet host-uniq=0x9400b600
12:54:32 pppoe,debug,packet service-name=BSNL ADSL
12:54:33 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:33 pppoe,debug,packet session-id=0x0000
12:54:33 pppoe,debug,packet host-uniq=0x9400b600
12:54:33 pppoe,debug,packet service-name=BSNL ADSL
12:54:34 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:34 pppoe,debug,packet session-id=0x0000
12:54:34 pppoe,debug,packet host-uniq=0x9400b600
12:54:34 pppoe,debug,packet service-name=BSNL ADSL
12:54:35 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:35 pppoe,debug,packet session-id=0x0000
12:54:35 pppoe,debug,packet host-uniq=0x9400b600
12:54:35 pppoe,debug,packet service-name=BSNL ADSL
12:54:36 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:36 pppoe,debug,packet session-id=0x0000
12:54:36 pppoe,debug,packet host-uniq=0x9400b600
12:54:36 pppoe,debug,packet service-name=BSNL ADSL
12:54:37 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:37 pppoe,debug,packet session-id=0x0000
12:54:37 pppoe,debug,packet host-uniq=0x9400b600
12:54:37 pppoe,debug,packet service-name=BSNL ADSL
12:54:38 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:38 pppoe,debug,packet session-id=0x0000
12:54:38 pppoe,debug,packet host-uniq=0x9400b600
12:54:38 pppoe,debug,packet service-name=BSNL ADSL
12:54:39 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
12:54:39 pppoe,debug,packet session-id=0x0000
12:54:39 pppoe,debug,packet host-uniq=0x9400b600
12:54:39 pppoe,debug,packet service-name=BSNL ADSL
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: CCP close
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: BCP close
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: IPCP close
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: IPV6CP close
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: MPLSCP close
12:54:40 pppoe,ppp,info pppoe-out1-bsnl-adsl: terminating... - disconnected
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: LCP lowerdown
12:54:40 pppoe,ppp,debug pppoe-out1-bsnl-adsl: LCP down event in initial state
12:54:40 pppoe,ppp,info pppoe-out1-bsnl-adsl: disconnected
I can confirm that nothing has gone wrong with the modem itself as I can use it in modem-router mode successfully. If I do use it as modem-router, the internet could be connected as you can see from the limited log provided my that modem-router…
3/23/2019 12:59:30 If(PPPoE1) PPP connection ok !
03/23/2019 12:59:29 PPPoE1 get IP:123.123.123.123
03/23/2019 12:59:29 PPPoE1 start PPP
03/23/2019 12:59:29 PPPoE receive PADS
03/23/2019 12:59:28 PPPoE send PADR
03/23/2019 12:59:28 PPPoE receive PADO
03/23/2019 12:59:28 PPPoE send PADI
03/23/2019 12:59:28 ADSL Media Up !
Here’s my RouterOS config export (with some hidden information mentioned as xyz)…
# mar/23/2019 13:17:48 by RouterOS 6.44.1
# software id = KBW2-46HF
# model = RBD52G-5HacD2HnD
# serial number = xyz
add admin-mac=B8:69:F4:20:C6:AF auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=disabled name=pppoe-out1-bsnl-adsl service-name="BSNL ADSL" user=xyz
/interface l2tp-client
add add-default-route=yes connect-to=work.tinywp.com keepalive-timeout=disabled name=l2tp-out1-work use-ipsec=yes user=xyz
/interface l2tp-server
add name=l2tp-in1-vpn user=xyz
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=india disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=india disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik5 \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile supplicant-identity=MikroTik
/interface wireless
add disabled=no mac-address=BA:69:F4:20:C6:B4 master-interface=wlan2 name=wlan3 security-profile=profile ssid=MikroGuests
add disabled=no mac-address=BA:69:F4:20:C6:B3 master-interface=wlan1 name=wlan4 security-profile=profile ssid=MikroGuests
/ip hotspot profile
add name=dhcp ranges=192.168.18.10-192.168.18.254
add name=vpn ranges=192.168.19.2-192.168.19.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.19.1 remote-address=vpn
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
/interface wireless access-list
add ap-tx-limit=1000000 interface=wlan4
add ap-tx-limit=1000000 interface=wlan3
add address=192.168.18.1/24 comment=defconf interface=ether2 network=192.168.18.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no
add add-default-route=no dhcp-options=clientid,hostname disabled=no use-peer-dns=no use-peer-ntp=no
add address=192.168.18.0/24 comment=defconf gateway=192.168.18.1 netmask=24
set servers=176.103.130.130,9.9.9.9,1.0.0.1,8.4.4.8
/ip dns static
add address=192.168.18.1 name=router.lan
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" disabled=yes dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" disabled=yes dst-port=443 protocol=tcp
# l2tp-in1-vpn not ready
add action=accept chain=input in-interface=l2tp-in1-vpn
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.19.0/24
# lte1 not ready
add action=masquerade chain=srcnat out-interface=*E
# pppoe-out1-bsnl-adsl not ready
add action=masquerade chain=srcnat out-interface=pppoe-out1-bsnl-adsl
add comment="Belkin default" distance=1 gateway=192.168.2.1
add comment="Belkin custom" distance=1 gateway=192.168.83.1
add check-gateway=ping distance=2 gateway=192.168.42.129
add comment="Netgear Router" disabled=yes distance=1 gateway=192.168.75.1
add disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=l2tp-out1-work pref-src=192.168.19.1
/ip ssh
set allow-none-crypto=yes
/ppp secret
add name=xyz
/system clock
set time-zone-name=Asia/Kolkata
/system scheduler
add interval=1d name="Take backups" on-event=backup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=feb/05/2019 start-time=05:30:00
add name=reboot_alert on-event=reboot_alert policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
/tool mac-server
/tool mac-server mac-winbox
What could have gone wrong? Could it be a bug with the latest version of RouterOS?
