I have a problem with connecting my RB7601GS (6.47.9) to my ISP provider over PPPoE.
Logs
08:22:40 pppoe,ppp,info pppoe-out1: connecting...
08:22:50 pppoe,ppp,info pppoe-out1: terminating... - disconnected
08:22:50 pppoe,ppp,info pppoe-out1: disconnected
08:23:00 pppoe,ppp,info pppoe-out1: initializing...
08:23:00 pppoe,ppp,info pppoe-out1: connecting...
08:23:10 pppoe,ppp,info pppoe-out1: terminating... - disconnected
08:23:10 pppoe,ppp,info pppoe-out1: disconnected
08:23:20 pppoe,ppp,info pppoe-out1: initializing...
08:23:20 pppoe,ppp,info pppoe-out1: connecting...
08:23:30 pppoe,ppp,info pppoe-out1: terminating... - disconnected
My setup
# software id = XL0Q-P1P0
# model = RB760iGS
add name=kawa_lan protocol-mode=none
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=xxx user=FMPPP_xxxxx@finemedia.pl
/ip hotspot profile
add name=pool_lan ranges=10.21.37.100-10.21.37.254
add address-pool=pool_lan disabled=no interface=kawa_lan lease-time=6m name=\
server_lan
add bridge=kawa_lan interface=ether2
set discover-interface-list=none
add address=10.21.37.1/24 interface=kawa_lan network=10.21.37.0
add address=10.21.37.0/24 dns-server=10.21.37.1 gateway=10.21.37.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward connection-nat-state=dstnat
add action=drop chain=forward
add action=accept chain=output
add action=accept chain=input connection-state=established,related
add action=accept chain=input icmp-options=8:0 protocol=icmp
add action=accept chain=input icmp-options=3:4 protocol=icmp
add action=accept chain=forward in-interface=kawa_lan out-interface=ether1 \
src-address=10.21.37.0/24
add action=accept chain=input connection-state=new dst-address=10.21.37.1 \
dst-port=53 in-interface=kawa_lan protocol=udp src-address=10.21.37.0/24
dst-port=8291 in-interface=kawa_lan protocol=tcp src-address=\
10.21.37.0/24
add action=drop chain=input
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
I tested the connection on Windows with cable directly plugged to PC instead of mikrotik and it works fine when i create PPPoE on windows creator, so connection and login/pass are correct
