PPPoe client causing PPPoe server to reboot
Apologies if is this is a duplicate post. The previous one was submitted but appears not to have made it to the forum.
Scenario:
PPPOE-Server <—> Highsite <—> Highsite <—> Highsite with AP
PPPoe Server is X86, ROS v6.27 running in a VMware ESXi 5.5 environment.
Highsite is RB mipsbe ROS v6.27 connected to PPPoe server via routed wireless backhaul.
All access points are UBNT devices in bridge mode, WDS enabled.
EOIP tunnel is created between Highsite with AP and PPPoe Server. Bridge is created on Highsite with AP using ports of AP Ethernet and EOIP Tunnel. On PPPoe Server a PPPoe Server is bound to the EOIP tunnel. No bridging there.
I have a problem that occurs when any client connects to one of our highsites using a mikrotik device and they have mrru=1600 set in their pppoe-client. It causes our main pppoe server to reboot as soon as some throughput occurs on the PPPoe tunnel. Workaround is to set mrru=disabled.
Seems a huge exploit hole in ROS unless its VMWare related.
Can someone provide a reason for why it occurs?
Is it related to the bridging?
Configuration on Highsite:
/interface eoip add local-address=y.y.y.y name=tunnel_ap1 remote-address=z.z.z.z tunnel-id=11
/interface bridge add name=bridge_ap1 protocol-mode=none
/interface bridge port add bridge=bridge_ap1 interface=tunnel_ap1
/interface bridge port add bridge=bridge_ap1 interface=“ethernet_ap1”
Configuration on PPPoe Server:
/interface eoip add local-address=z.z.z.z mtu=1458 name=ppp_ap1 remote-address=y.y.y.y tunnel-id=11
/interface pppoe-server server add default-profile=internet disabled=no interface=ppp_ap1 max-mru=1480 max-mtu=1480 mrru=1600
/ppp profile add change-tcp-mss=yes dns-server=a.a.a.a local-address=b.b.b.b name=inet use-compression=yes use-encryption=yes use-vj-compression=yes
Any helpfull explanation / discussion welcomed.
