PPPoE client connected but no internet
I am using RB750 configured with PPPoE client on port 1. PPPoE client says it is connected. ISP assigned an ip address. But I cannot get any internet connection. Ping from router gets nothing.
Here are my configures.
[admin@MikroTik] > ip firewall export
# jan/02/1970 00:17:28 by RouterOS 4.5
# software id = YESW-SR6F
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="" disabled=no dst-port=8291 protocol=tcp
add action=accept chain=input comment="" disabled=no dst-port=23 protocol=tcp
add action=accept chain=input comment="" disabled=no dst-port=22 protocol=tcp
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no in-interface=\
    ether1-gateway
add action=accept chain=input comment="default configuration" connection-state=related disabled=no in-interface=\
    ether1-gateway
add action=drop chain=input comment="default configuration" disabled=yes in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-gateway \
    dst-address=0.0.0.0/0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
[admin@MikroTik] > ip address export
# jan/02/1970 00:17:54 by RouterOS 4.5
add address=192.168.88.1/24 broadcast=192.168.88.255 comment="default configuration" disabled=no interface=\
    ether2-local-master network=192.168.88.0
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   ;;; default configuration
     192.168.88.1/24    192.168.88.0    192.168.88.255  ether2-local-master
 1 D 122.150.60.4/32    203.134.4.180   0.0.0.0         pppoe-out1
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 ADS  0.0.0.0/0                          203.134.4.180      1
 1 ADC  192.168.88.0/24    192.168.88.1    ether2-local-ma... 0
 2 ADC  203.134.4.180/32   122.150.60.4    pppoe-out1         0
[admin@MikroTik] > /interface pppoe-client print
 0  R name="pppoe-out1" max-mtu=1480 max-mru=1480 mrru=disabled interface=ether1-gateway
      user="username" password="password" profile=default service-name="" ac-name=""
      add-default-route=yes dial-on-demand=yes use-peer-dns=yes allow=pap,chap,mschap1,mschap2
00:10:25 pppoe,ppp,info pppoe-out1: initializing...
00:10:25 pppoe,ppp,info pppoe-out1: waiting for packets...
00:10:26 pppoe,ppp,info pppoe-out1: dialing...
00:10:26 pppoe,ppp,info pppoe-out1: authenticated
00:10:26 pppoe,ppp,info pppoe-out1: connected
ROS runing on your device is ancient. Upgrade it to latest available for your device (globally that would be 6.46.x, I’m not sure if your vintage RB750 is still supported).
Probably you’d be better off setting dial-on-demand=no on pppoe-client configuration.
And enable your last firewall rule (drop everything else), without it your router will get hacked within minutes after you establish internet connectivity. At the same time, add another rule similar to the last one, but using in-interface=pppoe-out1.
How do I upgrade to 6.x? Net install?
System → Packages → Check for Updates → Download and Install
750’s are fine with recent RouterOS - I have one running v6.44.6 doing minor stuff, but due to the limited RAM disable packages you are not using (e.g. hotspot, ipv6, mpls, routing, wireless).
Not sure if you can upgrade directly from 4.5 to 6.x, going via 5.26 may work or use netinstall.
I will try to upgrade to 5.x
But I still have no internet. I did what @mkx said.
I have made some progress. I have upgraded to 6.40.8. MK router can ping and access the internet. But LAN does not have access to internet.
# apr/30/2020 09:16:41 by RouterOS 6.40.8
# model = 750
# serial number = 21990187F350
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=pppoe-out1
add action=accept chain=input comment="default configuration" connection-state=established in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" dst-address=0.0.0.0 out-interface=pppoe-out1 \
    to-addresses=0.0.0.0
 0 ADS  0.0.0.0/0                          pppoe-out1                1
 1 ADC  192.168.88.0/24    192.168.88.1    bridge1                   0
 2 ADC  203.134.4.179/32   122.150.60.4    pppoe-out1                0
There are still significant vulnerabilities in versions prior to v6.44.x.
Having upgraded from such an old version I would strongly suggest resetting to the default configuration, disable the default WAN DHCP client, add a PPPoE client, add the PPPoE client interface to the WAN interface list - the last step is important as it enables NAT for LAN to WAN traffic.
All good now! Thank you!
On your first post you had:
Which obviously is wrong, your out interface is not eth1 but the PPPoE client… This wrong rule does not keep the router from having access to the Internet, but your Lan…
So i am not sure that resetting the router did the trick, i just suppose the second time you did configure the router you made the correct rule on your NAT…
However i do agree, in some cases we have to first reset and then install a new ROS, in case of very old versions just like you had. But i do not consider it a must.
In case something does not work as it should or breaks, you can manually most of the times fix it…
It was changed in post #7 to
add action=masquerade chain=srcnat comment="default configuration" dst-address=0.0.0.0 out-interface=pppoe-out1 to-addresses=0.0.0.0
which should have worked fine, so given the mimimal configuration changes and the huge jump in versions resetting to get a better default configuration seemed prudent.
