PPPoE Client Encryption negotiation rejected
My ISP changed the connection to the Internet from Static-IP to PPPoE-Dailing so I had configured a PPPoEClient on the ethernet1-Interface with my username and password.
dail an demand is disabled and
add-default-route, use-peer-dns is enabled.
the Mt router begins dailing
connected but after 2 seconds the connection is terminated with the log message Encryption negotiation rejected.
Has anybody an Idea what happens?
When connect diect with an Windowx XP PC it works.
Status form the Windows XP connection is:
Gerätename WAN-Miniport(PPPOE)
Gerätetyp PPPoE
Servertyp PPP
Übertragungen TCP/IP
Authentifizierung MD5 CHAP
PPP-Multilinkframing Inaktiv
Server-IP-Adresse 10.10.10.221
Client-IP-Adresse 62.152.161.3
Thank you for your help!!
Could you post the config of your pppoe client interface?
Ok i have found the problem!
The problem is the default profile.
In that pofile i have checked the require encryption
and then the MT-Router is waiting for the encryption but my ISP doesn`t support PPPoE-encryption.
Thought something like that… :wink:
Glad to hear you solved it!
