I upgraded CRS-125 from 6.32.3 to 6.34.6 and pppoe-client was not able to connect via ADSL line (ADSL modem is in bridge mode).
There was no configuration change. Before upgrade, router was working through ADSL more than 6 months. Downgrade to 6.32.4 solved this issue.
Be carefully with upgrade to this “Bugfix only” release if you depend on ADSL.
Configuration is quite simple:
[code]/interface pppoe-client add name=ether24 user=ADSL password=ADSL interface=adsl-tmob add-default-route=yes use-peer-dns=no max-mtu=1492;
ppp profile print
0 * name=“default” use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes address-list=“”[/code]
Logs from 6.34.6 with “topics=pppoe,debug,!packet” enabled:
12:22:34 pppoe,ppp,info adsl-tmob: initializing...
12:22:34 pppoe,ppp,info adsl-tmob: connecting...
12:22:34 pppoe,ppp,debug adsl-tmob: LCP lowerup
12:22:34 pppoe,ppp,debug adsl-tmob: LCP open
12:22:34 pppoe,ppp,debug adsl-tmob: LCP timer
12:22:34 pppoe,ppp,debug adsl-tmob: LCP opened
12:22:35 pppoe,ppp,info adsl-tmob: authenticated
12:22:35 pppoe,ppp,debug adsl-tmob: IPCP lowerup
12:22:35 pppoe,ppp,debug adsl-tmob: IPCP open
12:22:35 pppoe,ppp,debug adsl-tmob: IPV6CP open
12:22:35 pppoe,ppp,debug adsl-tmob: MPLSCP lowerup
12:22:35 pppoe,ppp,debug adsl-tmob: MPLSCP open
12:22:35 pppoe,ppp,debug adsl-tmob: BCP open
12:22:35 pppoe,ppp,debug adsl-tmob: CCP lowerup
12:22:35 pppoe,ppp,debug adsl-tmob: CCP open
12:22:35 pppoe,ppp,debug adsl-tmob: IPCP opened
12:22:35 pppoe,ppp,info adsl-tmob: connected
12:22:36 pppoe,ppp,debug adsl-tmob: LCP missed echo reply
12:22:36 pppoe,ppp,debug adsl-tmob: LCP lowerdown
12:22:36 pppoe,ppp,debug adsl-tmob: LCP closed
12:22:36 pppoe,ppp,debug adsl-tmob: CCP lowerdown
12:22:36 pppoe,ppp,debug adsl-tmob: BCP lowerdown
12:22:36 pppoe,ppp,debug adsl-tmob: BCP down event in starting state
12:22:36 pppoe,ppp,debug adsl-tmob: IPCP lowerdown
12:22:36 pppoe,ppp,debug adsl-tmob: IPCP closed
12:22:36 pppoe,ppp,debug adsl-tmob: IPV6CP lowerdown
12:22:36 pppoe,ppp,debug adsl-tmob: IPV6CP down event in starting state
12:22:36 pppoe,ppp,debug adsl-tmob: MPLSCP lowerdown
12:22:36 pppoe,ppp,info adsl-tmob: terminating... - hungup
12:22:36 pppoe,ppp,debug adsl-tmob: LCP down event in starting state
12:22:36 pppoe,ppp,info adsl-tmob: disconnected
12:22:36 pppoe,ppp,info adsl-tmob: initializing...
12:22:36 pppoe,ppp,info adsl-tmob: connecting...
12:22:38 pppoe,debug ether24: received PADO with unknown host-uniq, dropping
12:23:08 pppoe,ppp,info adsl-tmob: terminating... - disconnected
12:23:08 pppoe,ppp,debug adsl-tmob: LCP lowerdown
12:23:08 pppoe,ppp,debug adsl-tmob: LCP down event in starting state
12:23:08 pppoe,ppp,info adsl-tmob: disconnected
12:23:08 pppoe,ppp,info adsl-tmob: initializing...
12:23:08 pppoe,ppp,info adsl-tmob: connecting...
12:23:39 pppoe,ppp,info adsl-tmob: terminating... - disconnected
12:23:39 pppoe,ppp,debug adsl-tmob: LCP lowerdown
12:23:39 pppoe,ppp,debug adsl-tmob: LCP down event in starting state
12:23:39 pppoe,ppp,info adsl-tmob: disconnected
12:23:40 pppoe,ppp,info adsl-tmob: initializing...
12:23:40 pppoe,ppp,info adsl-tmob: connecting...
12:24:14 pppoe,ppp,info adsl-tmob: terminating... - disconnected
12:24:14 pppoe,ppp,debug adsl-tmob: LCP lowerdown
12:24:14 pppoe,ppp,debug adsl-tmob: LCP down event in starting state
12:24:14 pppoe,ppp,info adsl-tmob: disconnected
12:24:15 pppoe,ppp,info adsl-tmob: initializing...
12:24:15 pppoe,ppp,info adsl-tmob: connecting...
12:24:21 pppoe,ppp,debug adsl-tmob: LCP lowerup
12:24:21 pppoe,ppp,debug adsl-tmob: LCP open
12:24:21 pppoe,ppp,debug adsl-tmob: LCP timer
12:24:21 pppoe,ppp,debug adsl-tmob: LCP opened
12:24:21 pppoe,ppp,info adsl-tmob: authenticated
12:24:21 pppoe,ppp,debug adsl-tmob: IPCP lowerup
12:24:21 pppoe,ppp,debug adsl-tmob: IPCP open
12:24:21 pppoe,ppp,debug adsl-tmob: IPV6CP open
12:24:21 pppoe,ppp,debug adsl-tmob: MPLSCP lowerup
12:24:21 pppoe,ppp,debug adsl-tmob: MPLSCP open
12:24:21 pppoe,ppp,debug adsl-tmob: BCP open
12:24:21 pppoe,ppp,debug adsl-tmob: CCP lowerup
12:24:21 pppoe,ppp,debug adsl-tmob: CCP open
12:24:22 pppoe,ppp,debug adsl-tmob: IPCP opened
12:24:22 pppoe,ppp,info adsl-tmob: connected
12:24:22 pppoe,ppp,debug adsl-tmob: LCP missed echo reply
12:24:23 pppoe,ppp,debug adsl-tmob: LCP lowerdown
12:24:23 pppoe,ppp,debug adsl-tmob: LCP closed
12:24:23 pppoe,ppp,debug adsl-tmob: CCP lowerdown
12:24:23 pppoe,ppp,debug adsl-tmob: BCP lowerdown
12:24:23 pppoe,ppp,debug adsl-tmob: BCP down event in starting state
12:24:23 pppoe,ppp,debug adsl-tmob: IPCP lowerdown
12:24:23 pppoe,ppp,debug adsl-tmob: IPCP closed
12:24:23 pppoe,ppp,debug adsl-tmob: IPV6CP lowerdown
12:24:23 pppoe,ppp,debug adsl-tmob: IPV6CP down event in starting state
12:24:23 pppoe,ppp,debug adsl-tmob: MPLSCP lowerdown
12:24:23 pppoe,ppp,info adsl-tmob: terminating... - hungup
12:24:23 pppoe,ppp,debug adsl-tmob: LCP down event in starting state
12:24:23 pppoe,ppp,info adsl-tmob: disconnected
12:24:26 pppoe,ppp,info adsl-tmob: initializing...
12:24:26 pppoe,ppp,info adsl-tmob: connecting...
12:24:28 pppoe,debug ether24: received PADO with unknown host-uniq, dropping
