I have an RB2011UAS router and configured it up with two internet connections, one is direct with PPPoE, and one is with a PPPoA modem then the Mikrotik uses PPPoE to login.
Both connections log in fine but it seems the speed over these links cannot get above 2Mbps down and one of them is able to go up to 60Mbps on it’s old router, and the other is able to go to 6Mbps down.
I did have both plugged into the 100Mb ethernet ports on the firewall but I found a short term fix to get the primary link faster as plugging the 60Meg internet into a gigabit port.
Now, for the 60Meg connection I know the other end is a Mikrotik firewall so I was hoping the two would interact well but it seems it’s not
Does anyone have any suggestions into what can be tried to make it perform at it’s correct speed?
