PPPOE Client problems
hi all
I am having a problem connecting a Mikrotik to a PPPOE connection
It dials but will not redial if disconnected
Any ideas
regards
malcolm
set “Dial on Demand” in the Client settings of on.
dingsingo
Tried that already
It does not close the old connection
Any ideas
regards
Malcolm
Hi
Your pppoe server have the conexions time out enable ?
Try to enable this with 30 sec
if a PPPOE conexions is close the Mikrotik kill the conexions .
or
IF you use a Radius server check the dictionary is the Mikrotik
beacause the radius send the conexions close at your mikrotik .
tried this
