I’ve got a BTO modem connected to a homelab dslam. I need to setup a pppoe client that will use
Username: bthomehub@btbroadband.com
Password: BT
VLAN: 101
and then a ppooe server to actually finish the connection and assign an ip. This is my config so far the BTO modem lan is plugged into port 20 of the mikrotik.
Here is my NON working config so far please could someone point out where i’m going wrong.
/interface vlan
add interface=ether20 name=vlan101 vlan-id=101
/interface pppoe-client
add add-default-route=yes dial-on-demand=yes disabled=no interface=vlan101 \
name=pppoe-out1 use-peer-dns=yes user=bthomehub@btbroadband.com
add name=vlan101_pool ranges=10.78.0.1-10.78.0.253
add address-pool=vlan101_pool interface=vlan101 name=vlan101_dhcp
/ppp profile
set *0 change-tcp-mss=no
/interface pppoe-server server
add disabled=no interface=ether20 service-name=service1
add address=10.78.0.254/24 interface=pppoe-out1 network=10.78.0.0
add address=10.78.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.78.0.254 \
netmask=24
/ppp secret
add name=bthomehub@btbroadband.com
