PPPOE client throuth another router
I have two routers one is connected on ISP (wireless) and to get internet i need to connect to setup pppoe client. The thing i wanted to configure i that my “core” router is connected to pppoe and not one that is sitting on my roof.
Any idea how can i do this?
Both routes are in 192.168.5.0/24 subnet router that i want to connect as pppoe client is 192.168.5.1 and one that makes wireless connection is 192.168.5.6
Is there any way to lets say bridge wireless card from router on roof to one in my room ? Hope you guys understand what I want to do.
Reply back if I miss some informations that I did not share.
Thanks in advance,
Danijel
As you said, you need to configure the wireless router as bridge transparent.
Create a bridge interface with arp=proxy arp. Add to this bridge the wireless and ethernet interfaces. Remove NAT from it, and check on the second router if you can connect to the pppoe-server.
