Hi guys
I used to have my gateway run on an server, but the hardware went out the door recently, so I’ve replaced it with a RB750 for now.
Luckly I had a backup of the config, but it seems not work entirely the same on the routerboard.
I have PPPoE listening on the same interface as the hotspot (I know, not recommended) and usually the PPPoE clients could connect to one of my servers I hosted locally on the hotspot range. Now on the routerboard this is not possible anymore. I can’t access anything on the hotspot range from PPPoE.
Is there something I should enable for this to work? What parts of the config should I paste for you guys to be able to help?
