Hi! I just got a RB951G-2HnD with ROS 6.9 and I’d like to know if my settings for PPPoE via an ADSL modem are correct.
Here’s my full export:
[admin@nietzsche] > export
# feb/12/2014 09:25:35 by RouterOS 6.9
# software id = DP0K-P9C8
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above distance=indoors l2mtu=2290 mode=ap-bridge \
ssid=MikroTik-BBB5D5
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-clients
set [ find default-name=ether3 ] name=ether3-servers
set [ find default-name=ether4 ] disabled=yes name=ether4-temp
set [ find default-name=ether5 ] disabled=yes name=ether5-temp
/ip neighbor discovery
set ether1-wan discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik \
wpa-pre-shared-key=418402BC7279 wpa2-pre-shared-key=418402BC7279
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=ether2-clients-dhcp-pool ranges=192.168.2.21-192.168.2.254
add address-pool=ether2-clients-dhcp-pool disabled=no interface=ether2-clients name=ether2-clients-dhcp
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 default-route-distance=1 dial-on-demand=no disabled=no \
interface=ether1-wan keepalive-timeout=disabled max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-out1 password=\
xxx profile=default service-name="" use-peer-dns=no user=xxx
add interface=ether2-clients
add interface=wlan1
add address=192.168.2.1/24 comment="default configuration" interface=ether2-clients network=192.168.2.0
add address=192.168.3.1/24 interface=ether3-servers network=192.168.3.0
add address=192.168.0.1/24 interface=ether4-temp network=192.168.0.0
add address=192.168.88.1/24 interface=ether5-temp network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-wan
/ip dhcp-server lease
add address=192.168.2.253 mac-address=2C:27:D7:CF:24:B0 server=ether2-clients-dhcp
add address=192.168.2.0/24 comment="default configuration" dns-server=192.168.2.1,8.8.8.8,8.8.4.4 gateway=192.168.2.1 \
netmask=24 ntp-server=0.0.0.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-wan
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add chain=input comment="Clients LAN" in-interface=ether2-clients src-address=192.168.2.0/24
add action=drop chain=input comment="Drop everything else"
add action=masquerade chain=srcnat comment="default configuration" out-interface=pppoe-out1
add action=masquerade chain=srcnat src-address=192.168.2.0/24
add action=masquerade chain=srcnat src-address=192.168.3.0/24
add action=dst-nat chain=dstnat dst-port=22 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.3.21 to-ports=22
/ip service
set telnet address=192.168.3.0/24,192.168.2.0/24
set ftp address=192.168.3.0/24,192.168.2.0/24
set www address=192.168.3.0/24,192.168.2.0/24
set ssh address=192.168.3.0/24,192.168.2.0/24 disabled=yes
set www-ssl address=192.168.3.0/24,192.168.2.0/24
set api address=192.168.3.0/24,192.168.2.0/24 disabled=yes
set winbox address=192.168.3.0/24,192.168.2.0/24
set api-ssl address=192.168.3.0/24,192.168.2.0/24 disabled=yes
/ip upnp
set allow-disable-external-interface=no
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=nietzsche
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes mode=unicast primary-ntp=193.204.114.232 secondary-ntp=193.204.114.233
/tool graphing interface
add interface=ether1-wan
add interface=ether3-servers
/tool graphing resource
add
/tool mac-server
add interface=ether4-temp
add interface=ether5-temp
add interface=wlan1
add
/tool mac-server mac-winbox
add interface=wlan1
add
Here’s my ip route print:
[admin@nietzsche] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 192.168.100.1 1
1 ADC 192.168.1.0/27 192.168.1.20 ether1-wan 0
2 ADC 192.168.2.0/24 192.168.2.1 ether2-clients 0
3 ADC 192.168.3.0/24 192.168.3.1 ether3-servers 0
4 ADC 192.168.100.1/32 87.4.65.92 pppoe-out1 0
As you can see, ether1-wan (where the modem is attached to) is getting an IP from it (192.168.1.20), so I can still access the modem configuration page on 192.168.1.1. Traffic is routed via pppoe-out1 and the masquerading is done on that interface too.
Is that how it should be or am I under double NAT? I have no control over the ADSL modem and I’m not sure if it’s correctly operating in bridged mode or not. Anyway, the internet is working fine with this configuration. ![]()
Second question is: is my DNS setting correct for DHCP? I want my clients to look into the static DNS pool of my router before querying 8.8.8.8 and 8.8.4.4…
Also, I can’t really figure out the need for a line like “add chain=input comment=“Clients LAN” in-interface=ether2-clients src-address=192.168.2.0/24” in my firewall … I’ve copied that config straight from the http://wiki.mikrotik.com/wiki/How_to_Connect_your_Home_Network_to_xDSL_Line page, but my network works anyway even without that.
Thanks a lot for your help!
