PPPOE connect problem
Hi forum.
I’m having problems with connect my CRS326-24G-2S+RM to my ISP.
I have a SpeedStream 4200 ADSL modem in bridge mode connected on ether2 port and mikrotik pppoe client connects successfully on my ISP 1.
I have too Intelbras ONU 110 (GPON) in bridge mode connected on ether3 port and mikrotik pppoe doesn’t connect on ISP 2.
Both ports is outside of mikrotik bridge.
Here connection log
jul/08 22:56:23 pppoe,ppp,info pppoe-internex: connecting...
jul/08 22:56:23 system,info device changed by admin
jul/08 22:56:23 pppoe,debug,packet ether3: sent PADI to FF:FF:FF:FF:FF:FF
jul/08 22:56:23 pppoe,debug,packet     session-id=0x0000
jul/08 22:56:23 pppoe,debug,packet     host-uniq=0xed642501
jul/08 22:56:23 pppoe,debug,packet     service-name=
jul/08 22:56:24 pppoe,debug,packet ether3: sent PADI to FF:FF:FF:FF:FF:FF
jul/08 22:56:24 pppoe,debug,packet     session-id=0x0000
jul/08 22:56:24 pppoe,debug,packet     host-uniq=0xed642501
jul/08 22:56:24 pppoe,debug,packet     service-name=
jul/08 22:56:25 pppoe,debug,packet ether3: sent PADI to FF:FF:FF:FF:FF:FF
jul/08 22:56:25 pppoe,debug,packet     session-id=0x0000
jul/08 22:56:25 pppoe,debug,packet     host-uniq=0xed642501
jul/08 22:56:25 pppoe,debug,packet     service-name=
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: CCP close
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: BCP close
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: IPCP close
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: IPV6CP close
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: MPLSCP close
jul/08 22:56:25 pppoe,ppp,info pppoe-internex: terminating...
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: LCP lowerdown
jul/08 22:56:25 pppoe,ppp,debug pppoe-internex: LCP down event in initial state
jul/08 22:56:25 pppoe,ppp,info pppoe-internex: disabled
It works fine if I create a pppoe connection on my windows computer and put interface on bridge but it doesn’t work on the mikrotik.
I captured some information using Wireshark.
Windows PPPOE
Frame 1: 40 bytes on wire (320 bits), 40 bytes captured (320 bits) on interface 0
Ethernet II, Src: AsustekC_7c:dd:c5 (30:5a:3a:7c:dd:c5), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
PPP-over-Ethernet Discovery
    0001 .... = Version: 1
    .... 0001 = Type: 1
    Code: Active Discovery Initiation (PADI) (0x09)
    Session ID: 0x0000
    Payload Length: 20
    PPPoE Tags
        Tag: Service-Name (0x0101)
        Tag Length: 0
        Tag: Host-Uniq (0x0103)
        Tag Length: 12
        Host-Uniq: 20000000000000003b000000
0000   ff ff ff ff ff ff 30 5a 3a 7c dd c5 88 63 11 09   ÿÿÿÿÿÿ0Z:|ÝÅ.c..
0010   00 00 00 14 01 01 00 00 01 03 00 0c 20 00 00 00   ............ ...
0020   00 00 00 00 3b 00 00 00                           ....;...
Mikrotik PPPOE
Frame 2: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Ethernet II, Src: Routerbo_c6:75:b6 (64:d1:54:c6:75:b6), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    .... 0001 = Type: 1
    Session ID: 0x0000
    Payload Length: 12
    PPPoE Tags
        Tag Length: 4
        Host-Uniq: 83002501
        Tag Length: 0
0000   ff ff ff ff ff ff 64 d1 54 c6 75 b6 88 63 11 09   ÿÿÿÿÿÿdÑTÆu¶.c..
0010   00 00 00 0c 01 03 00 04 83 00 25 01 01 01 00 00   ..........%.....
0020   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................
0030   00 00 00 00 00 00 00 00 00 00 00 00               ............
Any help will be welcome.
Thanks.
