PPPoE connection dropping
I had analyzed my log file and found that my PPPoE connection are dropping on a daily basis. My log file with the applied filter is below.
Nov 1 21:57:00 MikroTik info: pppoe-out: connected
Nov 2 21:57:01 MikroTik info: pppoe-out: connected
Nov 3 21:57:04 MikroTik info: pppoe-out: connected
Nov 4 21:57:04 MikroTik info: pppoe-out: connected
Nov 5 21:57:04 MikroTik info: pppoe-out: connected
Nov 6 21:57:04 MikroTik info: pppoe-out: connected
Nov 7 21:57:04 MikroTik info: pppoe-out: connected
Nov 8 21:57:05 MikroTik info: pppoe-out: connected
Nov 9 21:57:05 MikroTik info: pppoe-out: connected
How to configure PPPoE interface to stop doping connection?
Current config:
/interface pppoe-client
add disabled=no interface=ether1 keepalive-timeout=disabled name=pppoe-out password=*** use-peer-dns=yes user=***
Now I’m sure on 99% that connection is dropping on the ISP side. Because radius_default_session_timeout by default is 86400 seconds. I believe that it wouldn’t be changed because of if the billing period is over then the session will not be interrupted. And I will be able to use Internet with the $0 on my account.
