pppoe connection problem
Hello, I have a machine with Mikrotik v2.9.27 installed and three windows PCs connected to it using pppoe. The problem occures only on the two PCs. The problem is that 15-20 min after initiating a pppoe connection with the server the connection drops ( that is what says the mikrotik log) , but on the client machine the connection stays alive but the IP is 0.0.0.0 and only after restart you can reconnect again. It happens exactly the same way on the two PCs while on the other don’t. Any idias ?
update to 2.9.50
