PPPoE connection with gatway outside subnet
Hi Guys,
We have an issue here where a Mikrotik router connects via PPPoE to TPG in Australia.
The default gateway is not on the same WAN subnet so the dynamic gatway is showing in blue because it can not work out the interface to use. I can not set the interface.
IP 60.241.xxx.xxx
Subnet 255.255.255.0
Default GW 10.20.20.XXX
The monowall boxe works ok but RouterOS can’t use the connection.
Is there a wok around for this?
Cheers,
Dan
try interface routing:
/ip route add dst-address=10.20.20.0/24 gateway=uplink
