HELP! I can’t figure this out, and I am going CRAZY!!!
We have a small WISP setup with the following:
- PPPoE router is a MK RB1100AHx2 v5.24
- Multiple APs that are UBNT gear
- One PxP using tranzeo gear
- MOST residential clients are UBNT radios in router mode, with PPPoE enabled
- a few larger clients are setup with UBNT radios in bridge mode, with PPPoE on the CX router itself
- PPPoE authenticates to a RADIUS server
- REMOTE site has a few APs on a different ISP connection, but authenticates in via VPN
- Aircontrol is setup on a VLAN, and we have management ports enabled on that VLAN on the UBNT gear
REMOTE SITE
- RB 450 with PPPoE server enabled on one port on a VLAN, and this site seems to be all fine
- PPPoE stays up all the time, no issues really
- No Aircontrol setup here yet, but I ruled out Aircontrol by turning off the Aircontrol server and the clients still dropped
MAIN SITE
On RB1100AHx2 V5.24 (I’ve tried the newer v6 ROS, it didn’t help, it actually made things worse, so I have since downgraded. I also have purchased TWO CCR1036, they do the same thing basically)
- Each AP is plugged into the RB on its own interface
- RADIUS Manager server is plugged into its own interface (Freeradius, DMAsoftlab Radius Manager)
- PPPoE server is setup on each of the AP interfaces, each one has its own service name, IP pool, etc
PROBLEM:
What happens is on the MK the PPPoE connections will drop all at once, then come back seconds later. Usually it’s JUST the UBNT radios that are in router mode, HOWEVER two or three times a day ALL radios go offline. MK logs just say USERNAME logged out, XXXX XXXXX XXXXX XXX XX (Xs are random numbers).
I have tried various MTU settings, 1500, 1492, currently at 1480 in PPPoE server
I have tried various MTU settings on the client devices also
I have powered down the air control UBNT server thinking it MIGHT be causing the disconnects
The BRIDGED clients seem to stay up more often, yet SOME of them always drop at the same time as well
The ONE client on the Tranzeo link has been up solid for several days, however it WAS doing the same thing last week, its magically working OK now???
The logs on the RADIUS server don’t show anything wrong, and because the remote site uses this same RADIUS server without issue, I can’t see it being that, but maybe?
I tried to enable RADIUS logging, and it doesn’t show anything wrong, there is authentication and accounting traffic
I have tried to change the accounting interval in MK from 1mins to 2min to 10min, no effect
I have increased the RADIUS timeout to 5000ms but realistically I can’t see it being radius at this point as the other site doesn’t have issues
I’m not sure what the MK interface MTU should be set to (it’s currently 1500, and L2 MUT is 1592) - the ones plugged into APs, that’s the default settings
I’m so burnt out, confused and mad I don’t know where to go from here…
