PPPoE "could not determine remote IP address"
I have configured several MT Boxes, but one of the setups is giving me trouble. I configured a pppoe-client interface and connected the ADSL modem to the ethernet card. The interface does not get established and the log shows:
apr/27/2005 14:21:09 WirelessUOL: authenticated
apr/27/2005 14:21:10 WirelessUOL: terminating… - could not determine remote IP address
apr/27/2005 14:21:10 WirelessUOL: disconnected
apr/27/2005 14:21:13 WirelessUOL: initializing…
apr/27/2005 14:21:13 WirelessUOL: dialing…
apr/27/2005 14:21:13 WirelessUOL: authenticated
apr/27/2005 14:21:13 WirelessUOL: terminating… - could not determine remote IP address
apr/27/2005 14:21:13 WirelessUOL: disconnected
The settings for the interface are:
0 name=“WirelessUOL” mtu=1400 mru=1400 interface=eth-wireless user=“userXXX@domain” password=“XXXX” profile=default service-name=“Acceso” ac-name=“” add-default-route=no dial-on-demand=no use-peer-dns=no allow=mschap2,mschap1,chap,pap
I tested the ISP access with a Linksys broadband router and connects fine, so I think the problem belongs to me and my MT.
Has anyone ran before with this problem ?
Regards.
J.M.
Have a look at this thread.
http://forum.mikrotik.com/t/adsl-pppoe-problem-need-help/1749/1
Regards
Andrew
Duplicate deleted
Nope, the same thing…
I read the thread and sounds similar.
I am using MT version 2.8.23. In the past i’ve used users with @domain and they work fine. As the guy posting the problem in the other thread the @domain is used here in Argentina to route authentication to the ISP.
I talked with the technician that did the physical deplyment and is not really an ADSL, but a Broadband Wireless that uses PPPoE. It should be the same thing, whatsoever…
Does someone run in this ?
Regards.
J.M.
JM, decime si queres que te invite a la comunidad mikrotik de habla hispana, mandame un mail a lu2pcj at yahoo.com
Sorry, but this mail is Just invite this guy to hispan forum’s mikrotik.
Regards,
Maxi
