Hi…
I’ve created three different PPPoE server over the same interface of a MKT, as a concentrator.
But, when I run a scan on a client, I always see the same (the first) and no other, and I have problems to connect to second PPPoE server, as seems the client not see it.
Theres something wrong with it config, hat I can’t see the others?
I miss something? I followed steps to create the servers in the wiki.mikrotik manual.
Thanks in advance…
Post your actual configuration to get any useful feedback.
This is the PPPoE server and profiles configuration
/interface pppoe-server server
add authentication=pap disabled=no interface=vlan2 max-mru=1480
max-mtu=1480 mrru=1600 one-session-per-host=yes service-name=customer1
max-mtu=1480 mrru=1600 one-session-per-host=yes service-name=customer2
max-mtu=1480 mrru=1600 one-session-per-host=yes service-name=customer3
/ppp secret
add local-address=192.168.1.1 name=customer1 profile=5M/2M remote-address=
2.2.2.2 service=pppoe
add local-address=192.168.1.1 name=customer2 profile=10Mbps/3Mbps
remote-address=2.2.2.3 service=pppoe
add local-address=192.168.1.1 name=customer3 profile=10Mbps/3Mbps
remote-address=2.2.2.4 service=pppoe
When I made a scan from Customer 3 router, I found:
interface pppoe-client scan interface=vlan2
SERVICE MAC-ADDRESS AC-NAME
customer1 74:4D:XX:XX:XX:XX RB960PGS - Central Router
I would not expect binding multiple servers to the same interface to work as only one can listen to the PPPoE ethertypes, multiple servers each on a different interface is fine.
Why are your attempting to run multiple services on the same interface as any parameters can be set in the client PPP secret?
you 100% can run multiple PPPoE servers on a single downstream interface - this is precisely why ‘Service Name’ was invented - so based on which service tag was issued it’d know which PPPoE server it was for.
Why you are only seeing one, I don’t know - might have something to do with the scan tool only seeing the first PADO and reporting it, or because they all share the same MAC technically so it still see’s it as a single concentrator.
Does it actually work if you PPP on multiple clients using the difference service names and their secrets?
Is there a reason you are using service names at all? You could have a single PPPoE Server and the customers are still differentiated by their secrets so there won’t be any crossover.
I find service name only helpful in dynamic users using outside auth (like RADIUS) where you need to apply a different profile based on service type - looks like with your way you are just creating a server each and a secret each, where given its local auth you could potentially put any differences required in the secrets config.
Joe, I thnik too that is related to this…
“might have something to do with the scan tool only seeing the first PADO and reporting it, or because they all share the same MAC technically so it still see’s it as a single concentrator”
Anyway, tthe PPPoE are working fine, but the fisrt connection after it’s installed, it’s pretty anoying to scan and bound it.
I’ll leave the current names, as you said, to see if something change.
Thanks!
What is the reason that you are creating more than one PPPoE Server in the same interface! There is no logical reason for me, however you will see only the one because he has priority and is in the same L2 Broadcast Domain!
Packet sniffing and Wireshark are very helpful when dealing with this type of issues. If the PADI from the client doesn’t contain a name of the required service, Mikrotik responds with a single PADO, listing all the services available:
PPP-over-Ethernet Discovery
0001 .... = Version: 1
.... 0001 = Type: 1
Code: Active Discovery Offer (PADO) (0x07)
Session ID: 0x0000
Payload Length: 64
PPPoE Tags
Host-Uniq: 58003c00
AC-Name: HyperV-CHR-3
Service-Name: service1
Service-Name: service2
Service-Name: service3
So it is up to the scanner how it deals with this information.
If the PADI already contains the name of the service, the Mikrotik also advertises all supported services in its PADO, but it lists the one requested in PADI at the first position.
Where logs are detailed enough, they can be even more useful because packet sniffing and Wireshark show you what has happened, but only logs can show you why it has happened. In this particular case, Mikrotik’s log explains nothing:
21:37:04 pppoe,debug,packet bridge: rcvd PADI from 00:15:5D:FC:E9:04
21:37:04 pppoe,debug,packet session-id=0x0000
21:37:04 pppoe,debug,packet host-uniq=0xe8003c00
21:37:04 pppoe,debug,packet service-name=service2
21:37:04 pppoe,debug,packet bridge: sent PADO to 00:15:5D:FC:E9:04
21:37:04 pppoe,debug,packet ac-name=HyperV-CHR-3
21:37:04 pppoe,debug,packet service-name=service1
21:37:04 pppoe,debug,packet service-name=service3
