PPPOE default
are somebody now howe to disable default pppoe profile
(default service)???
please help!..
if you mean “ppp profile default” then you can not disable it. It is not default pppoe profile - it is default ppp profile for any ppp service. It can not be disabled because every ppp service needs one active profile. Make your own profile if you do not want to use that. Actually I do not understand why do you want to disable it
I actually have 2 pppoe serever and I want to have only one default service becouse many new ussers dont now how to create a default pppoe connection (to enter service name)
I think you are misunderstanding something!
PPPoE profile is inactive until you assign it to the PPPOE server, you can create your own profile and assign it to the server.
You can create server without service name.
Where is the problem?
I have 2 server but that 2 server is from 2 other side on my network
PPPOE works inside the Ethernet network - so both of them are in the same ethernet!
Only thing I am able to think of is to filter packets in firewall somewhere
if you have two different servers on the same network, both will be visible to the customer. disable the first pppoe server (in routeros “/ip pppoe server server”)
I also have only one server in my network ROS 2.8.28 , and I see in client side 2 available service - one is (Default Service) … and I dont see how to disable this first service .
ya i have this problem too ,i want to disable the default profile
