PPPOE Disconnect Client
Hello I have A serious issue
i have 1036CCR with around 700 PPPOE active client
once there is a sudden disconnect for more then 300-400 client at once
the CCR jam and start send disconnect request in the log while the clients tryoing to reconnect
the internet disconnect
ping on server delay time out and high delay respond
between 4-8 mints until the situation goes back normal
in the log shows all clients disconnected and reconnect all at once
no cpu usage cpu is normal 10%<
in the profile no resources is using cpu
in the firewall there is no nat
i use static route from the core router
i tried to decrease the number of clients by dividing the clients on 2 CCR
now i have 350 pppoe client connected on each and still have the same issue with less time 5 Mint<
i need help please
Can you post your ppp server settings and interfaces so we have a better understanding of what might be going on?
i have the same problem you have to delete all rules on firewall> nat including hotspot dynamic rules the problem will be solved
But that means you cant use hotspot and ppp on same mikrotik
any other ideas ?
