PPPoE Encoding is blank even if encryption required
Hello, I just want to confirm why my PPPoE Client has a blank Encoding even with a Required Encryption profile, and if its possible to solve:
# dec/21/2018 22:50:22 by RouterOS 6.43.7
# model = RouterBOARD 952Ui-5ac2nD
/ppp profile
add name=force-encryption change-tcp-mss=yes use-encryption=required
/interface pppoe-client print
Flags: X - disabled, I - invalid, R - running
 0  R name="pppoe-out1" mrru=disabled interface=ether1 user="****" password="****" profile=force-encryption keepalive-timeout=10 add-default-route=yes default-route-distance=1 dial-on-demand=no use-peer-dns=yes allow=pap,chap,mschap1,mschap2
/interface pppoe-client monitor
numbers: 0
          status: connected
          uptime: 14m29s
    active-links: 1
        encoding:
    service-name:
         ac-name: BRAS-3
          ac-mac: ****
             mtu: 1480
             mru: 1480
   local-address: ****
  remote-address: ****
I do not have access to the internet provider equipment or any other router, internet is working fine, Winbox and Telnet does not show the Encoding.
Many thanks for your attention.
