PPPOE Error Code
anybody can pls tell me .. why pppoe user authenticate failed log isnt showing in Red Colour .. even if anyone give wrong passwd or MAC mismatch is not… it is very difficult to findout from log..
post those logs, so we can see the problem
Dear Sir
here is the attached file..
When some user gave wrong pppoe username or passwd i got this info in Black colour
Some error like DHCP error is showing only REd…
RED color is used only for critical problems. User password mistake is not considered critical.
There is no way to change colors in Log.
but one of your router was This option.. Red.. it is very difficult to find out which user is giving bad username/passwd .
Like I said, the colors can’t be customized. Only CRITICAL errors are in red color.
i get this on pppoe wont connect
setup modem(bridgedout)------mikrotik-------pc
trying to let mikrotik dial out but it wont get this err if i bridge out the pc and set it up it works what could be the problems
pppoe is as follows
1 name=“Telkom” max-mtu=1480 max-mru=1480 mrru=disabled interface=ether2 user=“\r\nxxxxxxxxxxxxxxx” password=“xxxxxxxxxxxx” profile=default service-name=“” ac-name=“”
profile is as follows
0 * name=“default” use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes
add-default-route=yes dial-on-demand=no use-peer-dns=no allow=pap,chap,mschap1,mschap2
03:24:45 pppoe,ppp,info Telkom: terminating… - disconnected
03:24:45 pppoe,ppp,debug Telkom: LCP lowerdown
03:24:45 pppoe,ppp,debug Telkom: LCP down event in initial state
03:24:45 pppoe,ppp,info Telkom: disconnected
03:24:55 pppoe,ppp,info Telkom: initializing…
03:24:55 pppoe,ppp,info Telkom: dialing…
03:24:55 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:24:55 pppoe,debug,packet session-id=0x0000
03:24:55 pppoe,debug,packet host-uniq=0x4735
03:24:55 pppoe,debug,packet service-name=
03:24:56 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:24:56 pppoe,debug,packet session-id=0x0000
03:24:56 pppoe,debug,packet host-uniq=0x4735
03:24:56 pppoe,debug,packet service-name=
03:24:57 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:24:57 pppoe,debug,packet session-id=0x0000
03:24:57 pppoe,debug,packet host-uniq=0x4735
03:24:57 pppoe,debug,packet service-name=
03:24:58 pppoe,ppp,info Telkom: terminating… - disconnected
03:24:58 pppoe,ppp,debug Telkom: LCP lowerdown
03:24:58 pppoe,ppp,debug Telkom: LCP down event in initial state
03:24:58 pppoe,ppp,info Telkom: disconnected
03:25:08 pppoe,ppp,info Telkom: initializing…
03:25:08 pppoe,ppp,info Telkom: dialing…
03:25:08 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:25:08 pppoe,debug,packet session-id=0x0000
03:25:08 pppoe,debug,packet host-uniq=0x4736
03:25:08 pppoe,debug,packet service-name=
03:25:09 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:25:09 pppoe,debug,packet session-id=0x0000
03:25:09 pppoe,debug,packet host-uniq=0x4736
03:25:09 pppoe,debug,packet service-name=
03:25:10 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:25:10 pppoe,debug,packet session-id=0x0000
03:25:10 pppoe,debug,packet host-uniq=0x4736
03:25:10 pppoe,debug,packet service-name=
03:25:11 pppoe,ppp,info Telkom: terminating… - disconnected
03:25:11 pppoe,ppp,debug Telkom: LCP lowerdown
03:25:11 pppoe,ppp,debug Telkom: LCP down event in initial state
03:25:11 pppoe,ppp,info Telkom: disconnected
03:25:22 pppoe,ppp,info Telkom: initializing…
03:25:22 pppoe,ppp,info Telkom: dialing…
03:25:22 pppoe,debug,packet ether2: sent PADI to FF:FF:FF:FF:FF:FF
03:25:22 pppoe,debug,packet session-id=0x0000
03:25:22 pppoe,debug,packet host-uniq=0x4737
03:25:22 pppoe,debug,packet service-name=
