PPPoE external
Hello!
I have a RB433AH with 3 cards (3 wireless panels) in it PPPoE clients are connected, and it has overloaded the CPU.
I want to pass the PPPoE clients of the RB433AH to an RB3011, is this possible !? if yes, how.
Thank you very mutch!
Are the PPPoE Clients on Wan or WLAN side?
You can imagine PPPoE as layer 2 protocol, you should bridge interface between PPPoE server and PPPoE CPE to create L2 segment.
PPPOEs clientes is active on WLAN on RB433AH.
I want transfers PPPOE Clients for to RB3011.
I’ve already tried to redirect the PPPoE Server bridge, but I could not, sometimes I missed something I do not know.
I need help, to authenticate PPPoE clients connected in WLAN RB433 authenticate in RB3011.
Create VLAN/another L2 segment between RB3011 and CPE
RB3011(start PPPoE server here)------ether/vlan------RB433ah(bridge ether/vlan+wlan1/2/3)---------------PPPoE Client CPE
You can help me with this!?
WoW!
It Works.
Thank you very mutch.
I just could not create a bridge, if I create a bridge the Mikrotik connection drops.
But even without the bridge, it worked, it is authenticating the PPPoE with internet in the RB3011.
Is it possible for me to access the SXT antennas of the pppoe clients?
I can only access them if I plug ethernet cable on RB433AH.
