I’ve the following problem.
I’ve a wireless internet connection to a ‘local’ ISP. This wireless internet connection is made with a mikrotik SEXTANT G 5HPnD which is in bridge mode. They’re using PPPoE to give the IP’s.
My own RB2011 which is connected tho the receiving sextant is the PPPoE client.
Now i’ve the problem that the PPPoE connection sometimes get’s lost.
After losing the connection it’s trying to reconnect. But it’s taking several times before it’s connected.
There are 2 kind of errors:
16:13:09 pppoe,ppp,info pppoe-out1: terminating... - peer is not responding
16:13:09 pppoe,ppp,info pppoe-out1: disconnected
16:13:09 pppoe,ppp,info pppoe-out1: initializing...
16:13:09 pppoe,ppp,info pppoe-out1: connecting...
16:13:09 system,info item removed
16:13:19 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:13:19 pppoe,ppp,info pppoe-out1: disconnected
16:13:19 pppoe,ppp,info pppoe-out1: initializing...
16:13:19 pppoe,ppp,info pppoe-out1: connecting...
16:13:29 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:13:29 pppoe,ppp,info pppoe-out1: disconnected
16:13:29 pppoe,ppp,info pppoe-out1: initializing...
16:13:29 pppoe,ppp,info pppoe-out1: connecting...
16:13:40 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:13:40 pppoe,ppp,info pppoe-out1: disconnected
16:13:40 pppoe,ppp,info pppoe-out1: initializing...
16:13:40 pppoe,ppp,info pppoe-out1: connecting...
16:13:48 pppoe,ppp,info pppoe-out1: authenticated
16:13:48 pppoe,ppp,info pppoe-out1: connected
16:13:48 system,info item added
16:15:52 pppoe,ppp,info pppoe-out1: terminating... - peer is not responding
16:15:53 pppoe,ppp,info pppoe-out1: disconnected
16:15:53 system,info item removed
16:15:54 pppoe,ppp,info pppoe-out1: initializing...
16:15:54 pppoe,ppp,info pppoe-out1: connecting...
16:15:57 pppoe,ppp,info pppoe-out1: authenticated
16:15:57 pppoe,ppp,info pppoe-out1: connected
16:15:57 system,info item added
16:46:59 pppoe,ppp,info pppoe-out1: terminating... - peer is not responding
16:46:59 pppoe,ppp,info pppoe-out1: disconnected
16:46:59 pppoe,ppp,info pppoe-out1: initializing...
16:46:59 pppoe,ppp,info pppoe-out1: connecting...
16:46:59 system,info item removed
16:47:09 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:47:09 pppoe,ppp,info pppoe-out1: disconnected
16:47:09 pppoe,ppp,info pppoe-out1: initializing...
16:47:09 pppoe,ppp,info pppoe-out1: connecting...
16:47:19 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:47:19 pppoe,ppp,info pppoe-out1: disconnected
16:47:19 pppoe,ppp,info pppoe-out1: initializing...
16:47:19 pppoe,ppp,info pppoe-out1: connecting...
16:47:29 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:47:29 pppoe,ppp,info pppoe-out1: disconnected
16:47:30 pppoe,ppp,info pppoe-out1: initializing...
16:47:30 pppoe,ppp,info pppoe-out1: connecting...
16:47:40 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:47:40 pppoe,ppp,info pppoe-out1: disconnected
16:47:41 pppoe,ppp,info pppoe-out1: initializing...
16:47:41 pppoe,ppp,info pppoe-out1: connecting...
16:47:51 pppoe,ppp,info pppoe-out1: terminating... - disconnected
16:47:51 pppoe,ppp,info pppoe-out1: disconnected
16:47:54 pppoe,ppp,info pppoe-out1: initializing...
16:47:54 pppoe,ppp,info pppoe-out1: connecting...
16:47:56 pppoe,ppp,info pppoe-out1: terminating... - failed to authenticate ourselves to peer
16:47:56 pppoe,ppp,info pppoe-out1: disconnected
16:48:03 pppoe,ppp,info pppoe-out1: initializing...
16:48:03 pppoe,ppp,info pppoe-out1: connecting...
16:55:45 pppoe,ppp,info pppoe-out1: terminating... - failed to authenticate ourselves to peer
16:55:45 pppoe,ppp,info pppoe-out1: disconnected
16:55:55 pppoe,ppp,info pppoe-out1: initializing...
16:55:55 pppoe,ppp,info pppoe-out1: connecting...
16:55:55 pppoe,ppp,info pppoe-out1: authenticated
16:55:55 pppoe,ppp,info pppoe-out1: connected
What could be the problem? IS there a way to fix this on the client side?
Because the ISP(service) is CRAP!!! But i need it.. ![]()
