one question about freeradius & mikrotik attributes:
I need to pass in autentication section different IP, Netmask & gateway to my client without use “service name”.
now,
for IP → framed-IP-address
for netmask → framed-netmask
for gateway? Framed Route? But in the manual I dont see the regular expression to insert in the Framed-Route (or
Framed-Routing) field..
Yes, for Gateway Framed-Route is used, As in RADIUS documentation specified, you need to look at RFC for the Framed-Route format,
From the RFC,
For IP routes, it SHOULD contain a destination prefix in dotted quad form optionally followed by a slash and a decimal length specifier stating how many high order bits of the prefix to use. That is followed by a space, a gateway address in dotted quad form, a space, and one or more metrics separated by spaces. For example, “192.168.1.0/24 192.168.1.1 1 2 -1 3 400”. The length specifier may be omitted, in which case it defaults to 8 bits for class A prefixes, 16 bits for class B prefixes, and 24 bits for class C prefixes. For example, “192.168.1.0 192.168.1.1 1”.
Whenever the gateway address is specified as “0.0.0.0” the IP address of the user SHOULD be used as the gateway address.
I’ve:
PPPoE Server with FreeRadius reply & SQL database. I’ve created a dummy account in the database,
this account return a MikroTik Framed-IP=192.168.1.2 and Framed-Route=192.168.1.0 192.168.1.1 1
In the PPPoE Server default profile I NOT set the Local address, client connection not start!
Where are error?
How to pass the local address (pppoe gateway)?
