Hi all,
I have some problems with PPPoE. Suddenly customers began to disconnect form PPPoE server (MK).
All customerns are connected with wireless CPE (OSBridge, linksys with DD-WRT) that includes PPPoE or with PPPoE client (RASPPPoE) on the PC.
Is there a guidline to be followed when PPPoE is used on a wireless network? (bridges MTU, CPE MTU, PC MTU, AP data rate, latency time)
How should I go through my trobleshooting?
Ah yes! that is were I’ve been goining wrong, thanks Sten
set the RTS clients to 512 (for example) to help avoid hidden node issuses (leave defaults on the access point) or if your whole network is MikroTik use nstream with polling.
make sure every client / wireless link has enough signal and is stable, one dodgy one can possibly destablise the whole network (per AP)
Thank you Sten/HarvSki,
the network from “radio point of view” seems to be fine.
The problem is that I have some customers that contienes to log on/off my PPPoE concentrator (MK), while I’m stiil able to ping their CPE.
MTU is configured at 1452, I’m going crazy…
MTU has nothing to do with the PPPoE logging on/off. Sounds like a network relialbility problem to me or maybe the PPPoE client is set to logout if inactive.
Set up a netwatch on the clients IP (if this is static and not to do with the PPPoE connection) at quite a frequent interval and see if that gets disconnects, set up the script event to write to the log.
another option would be to ping the client from the mikrotik command line, the larger the packet the better the network must be to transport it so:
One of my users has a problem that Trillian (MSN, ICQ, …) gets disconnected for a sec. and connected again while on PPPoE connection… Still, pppoe stays connected, no problem… Other users doesn’t have that prob…
