Hello everyone !
We recently upgraded our network from unmanaged switches to Dlink-3526 managed switches. Before that there were about 20 unmanaged TP-Link switches in our network. Till that time MT pppoe was working great but from the day we changed the switches we are having problem that our client get connected properly but they don’t have Internet Access.
I am new with managed switches and the purpose of the switches was just to get control over the unused ports. All the switches are in default company settings, mean that all the ports are under one vlan.
Let me tell you that at the NOC side we used Dlink-3100-24TG switch that is having 16 Fiber ports and 8 copper ports. Every far-end switch is directly connected with 3100 switch over optical fiber.
If anybody knows about the Dlink switches settings required, like under port configuration there are various options such as TRAP etc etc may be any of the option from these list needs to be enabled or disabled to pass the proper bandwidth. Even sometimes I am not able to ping the switch, whereas its gateway IP is already added in Mikrotik.
Have you used Torch or Packet Sniffer on the interfaces to see what traffic is flowing?
Hallo! I noticed the same trouble trying to get pppoe connection over a vlan established over a managed switch.
In my configuration, I have this:
|PPPoE server over vlan1 (Mikrotik RB493)| ----> |layer 2 WDS wireless bridge| ----> |managed switch (Mikrotik RB750UP ports 2-5 in switch mode)| ----> |PPPoE client over vlan1 (Mikrotik RB750UP)| ;
With this configuration, the RB750UP PPPoE client hangs and can’t ping anything; I’m only able to access it by mac address, disable PPPoE client interface, reboot and re-obtain ip functionality on the device.
If I re-enable PPPoE on client, the same thing happens: I lose ip connection with this RB750UP (client PPPoE) and only mac address connection remains possible.
In my case the managed switch is, of course, the RB750UP in switch mode.
If I change this device from switch mode to bridge mode, all works well, vlan1 and PPPoE client returns working well.
So, where is the problem with “switch mode” ? I can’t understand this kind of bug.
I forgot: RouterOS version on RB750UP in switch mode is 6.1, on RB750UP PPPoE client is 6.2, on RB493 (PPPoE server) is 6.2 .
Try uploading the config that doesn’t seem to work.
Dear CelticComms, I don’t unterstand which configuration to upload.
Do you mean the managed switch configuration? (That of the RB750UP used as switch);
Or do you mean the PPPoE client configuration?
I think you mean the first, as it’s the one of this topic.
So, this is the simple switch configuration that doesn’t let PPPoE service over vlan to work:
set 4 poe-out=off
set 1 master-port=ether5 poe-out=off
set 2 master-port=ether5 poe-out=off
set 3 master-port=ether5 poe-out=off
And this is the configuration that works, instead, on the same machine (RB750UP):
add l2mtu=1598 name=bridge1
set 1 poe-out=off
set 2 poe-out=off
set 3 poe-out=off
set 4 poe-out=off
As you can see, if I run it in “switch mode” it acts as a switch but if you try to pass a vlan over it (beetwen two others routeros devices), it doesn’t work.
If I run it in “bridge mode”, it acts as a switch as before and it works also with any vlan passed over it.
What are the Switch settings on the 750UP?
CelticComms, this is the switch print:
/interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 S ether1 1500 D4:CA:6D:B1:A4:45 enabled
1 S ether2 1500 D4:CA:6D:B1:A4:46 enabled ether3 switch1
2 R ether3 1500 D4:CA:6D:B1:A4:47 enabled none switch1
3 RS ether4 1500 D4:CA:6D:B1:A4:48 enabled ether3 switch1
4 RS ether5 1500 D4:CA:6D:B1:A4:49 enabled ether3 switch1
/interface ethernet switch port> print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 ether2 switch1 fallback leave-as-is 0
1 ether3 switch1 fallback leave-as-is 0
2 ether4 switch1 fallback leave-as-is 0
3 ether5 switch1 fallback leave-as-is 0
4 switch1_cpu switch1 fallback leave-as-is 0
It’s all default.
I would remember that the issues are only when this switch is working connected to a layer2 WDS CPE: the vlan between one router (RB493G) and another doesn’t pass the layer 2 network composed by: RouterA(with vlan1) ->AP WDS → CPE WDS → switch (RB750UP in SWITCH mode) ->RouterB(with vlan2) ;
Instead if I do this network:
RouterA(with vlan1) ->AP WDS → CPE WDS → switch (RB750UP in BRIDGE mode) ->RouterB(with vlan2) ; all things work well and the vlan1 works between routerA and routerB.
If I use “RB750UP in SWITCH mode” standalone it works well as a switch and also with vlan passing over it.
Difficult question, according to me.
But it’s a very good point, because RB750UP is a good device to make a switch in a wireless node (it has poe instruments, voltage control, usb, ecc) and if you use it in bridge mode (instead of switch mode) it wastes lots of traffic capability.
With these settings the VLAN table may have an influence. Try setting the VLAN mode to disabled on all ports.
