PPPoE help V6 needed, imported from V3
I imported a backup from x86 which was running 3.x version into 6.7 RB951Ui-2HnD. Everything went smoothly, everything works, except one thing - it won’t connect the PPPoE connection to my ISP!
Tried everything, from changing the cables to changing the ports. It just says “connecting” and then “terminating… disconnected”.
Since the old router in VM x86 is still working, I tried to connect from it - voila - it connects momentarily.
Disabled connection on old one, tried to connect from RB, no luck. 10 minutes of “disconnected” happened, then I just enabled the interface on the old one and it connected right away.
Updated RB to 6.18, same thing happens. I don’t have any ideas anymore :frowning: Please help!
put on 3.x
“/ppp export”
results on forum
remember to hide password and username, but not cut anything.
on /ppp export there are only settings and secrets for the PPPoE server and VPN server, and nothing about PPPoE Client. If you really need those, I will post them (but I have like 20 profiles and 10 users). They can all connect to the router (new and old), but I can’t connect to the internet.
on /interface export I get this on NEW router:
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2
default-route-distance=1 dial-on-demand=no disabled=yes interface=ADSL
keepalive-timeout=disabled max-mru=1480 max-mtu=1480 mrru=disabled name=
“T-Com ADSL” password=xxxxxx profile=default service-name=“”
use-peer-dns=no user=nmijato@htnet-dsland on OLD router:
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=
“” dial-on-demand=no disabled=no interface=ADSL max-mru=1480 max-mtu=1480
mrru=disabled name=“T-Com ADSL” password=xxxxxxx profile=default
service-name=“” use-peer-dns=no user=nmijato1@htnet-dslIt is disabled now but it won’t connect when it is enabled anyway.
Wait LOL there is a number missing in the login… let me try to change that…
nope, still the same… NEW RB:
echo: pppoe,ppp,info INFO: T-Com ADSL: terminating… - disconnected
echo: pppoe,ppp,info INFO: T-Com ADSL: disconnected
[admin@MT-NEW] >
echo: pppoe,ppp,info INFO: T-Com ADSL: initializing…
echo: pppoe,ppp,info INFO: T-Com ADSL: connecting…
[admin@MT-NEW] >
[admin@MT-NEW] >
echo: pppoe,ppp,info INFO: T-Com ADSL: connecting…old RB:
[admin@HODNIK-NEW] >
(6 messages discarded)
echo: route,event,debug status=<LINK,LINKOK,IPSUPPORT,UP>
echo: route,event,debug mtu=1480
echo: route,event,debug lname=ppp0
echo: route,event,debug uname=T-Com ADSL
echo: route,event,debug Interface change
echo: route,event,debug id=4
echo: route,event,debug index=12855
echo: route,event,debug caps=400c
(8 messages discarded)
echo: route,event distance=1
echo: route,event scope=30
echo: route,event targetscope=10
echo: route,event nexthop= weight=0 address=172.29.252.92
echo: route,event origin-type=DYNAMIC
echo: route,event Added candidate route
echo: route,event DstAddress=172.29.252.92/32
echo: route,event Attributes
echo: route,event protocol=CONNECT
echo: route,event scope=10
echo: route,event targetscope=0
echo: route,event connet= address=78.0.21.226 netmask=255.255.255.255 if
aceIdx=12855
assuming you have write correctly the password, I want compare default profile, is why I ask for export…
I may have deleted some rules on the old & new one and that is why they're not identical but thats it:
NEW:
[admin@MT-NEW] > /ppp export
jan/02/1970 22:46:10 by RouterOS 6.18
software id = *********
/ppp profile
add dns-server=192.168.10.1 local-address=192.168.10.1 name="NOLIMIT PPPoE"
remote-address=pppoe-pool
add change-tcp-mss=yes dns-server=192.168.20.1 local-address=192.168.20.1 name=
"NOLIMIT VPN" remote-address=vpn-pool
add dns-server=192.168.1.252 local-address=192.168.50.1 name=
"NOLIMIT PPPoE 252" remote-address=pppoe-pool-252
add dns-server=192.168.1.252 local-address=192.168.40.1 name="NOLIMIT VPN 252"
add dns-server=192.168.10.1 local-address=192.168.10.1 name="32/32 PPPoE"
rate-limit=32000/32000 remote-address=pppoe-pool
"64/64 VPN" rate-limit=64000/64000 remote-address=vpn-pool
"4096/128 VPN" rate-limit=128000/4096000 remote-address=vpn-pool
use-encryption=required
"NOLIMIT VPN - S NETA" remote-address=vpn-pool use-encryption=required
"NOLIMIT PPPOE upload cap" rate-limit=128000/20000000 remote-address=
pppoe-pool
"768/128 VPN" rate-limit=128000/768000 remote-address=vpn-pool
add dns-server=192.168.10.1 local-address=192.168.10.1 name="4096/196 PPPoE"
rate-limit=196000/4096000 remote-address=pppoe-pool
"NOLIMIT VPN cap" rate-limit=128000/20000000 remote-address=vpn-pool
add dns-server=192.168.10.1 local-address=192.168.10.1 name="768/64 PPPoE"
rate-limit=64000/768000 remote-address=pppoe-pool
add dns-server=192.168.10.1 local-address=192.168.10.1 name="128/64 PPPoE"
rate-limit=64000/128000 remote-address=pppoe-pool
"NO LIMIT VPN LAN" remote-address=lan-pool
add change-tcp-mss=yes dns-server=192.168.20.1 idle-timeout=3m local-address=
192.168.20.1 name="192/192 VPN - s neta" rate-limit=192000/192000
remote-address=vpn-pool session-timeout=10m use-encryption=required
add dns-server=192.168.10.1 local-address=192.168.10.1 name="1024/64 PPPoE"
rate-limit=64000/1024000 remote-address=pppoe-pool
/ppp secret
add name=dakky@lan password=* profile="NOLIMIT PPPoE" remote-address=
192.168.10.5 service=pppoe
add name=dakky password=* profile="4096/128 VPN" remote-address=
192.168.20.254 service=pptp
add name=dakky@lap password=* profile="NOLIMIT PPPoE" remote-address=
192.168.10.3 service=pppoe
add name=d password=* profile="NOLIMIT PPPoE" remote-address=192.168.10.10
service=pppoe
add name=buda@lan password=* profile="4096/196 PPPoE" remote-address=
192.168.10.17 service=pppoe
add name=ilo@lan password=* profile="4096/196 PPPoE" remote-address=
192.168.10.12 service=pppoe
add name=dakky21 password=* profile="NOLIMIT VPN" remote-address=
192.168.20.253 service=pptpOLD:
[admin@HODNIK-NEW] > /ppp export
aug/25/2014 17:26:09 by RouterOS 3.16
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
add change-tcp-mss=default comment="" dns-server=192.168.10.1 local-address=
192.168.10.1 name="NOLIMIT PPPoE" only-one=default remote-address=
pppoe-pool use-compression=default use-encryption=default
add change-tcp-mss=yes comment="" dns-server=192.168.20.1 local-address=
192.168.20.1 name="NOLIMIT VPN" only-one=default remote-address=vpn-pool
add change-tcp-mss=default comment="" dns-server=192.168.1.252 local-address=
192.168.50.1 name="NOLIMIT PPPoE 252" only-one=default remote-address=
pppoe-pool-252 use-compression=default use-encryption=default
192.168.40.1 name="NOLIMIT VPN 252" only-one=default remote-address=
192.168.10.1 name="32/32 PPPoE" only-one=default rate-limit=32000/32000
remote-address=pppoe-pool use-compression=default use-encryption=default
192.168.20.1 name="64/64 VPN" only-one=default rate-limit=64000/64000
remote-address=vpn-pool use-compression=default use-encryption=default
192.168.20.1 name="4096/128 VPN" only-one=default rate-limit=
128000/4096000 remote-address=vpn-pool use-compression=default
use-encryption=required use-vj-compression=default
192.168.20.1 name="NOLIMIT VPN - S NETA" only-one=default remote-address=
vpn-pool use-compression=default use-encryption=required
192.168.10.1 name="NOLIMIT PPPOE upload cap" only-one=default rate-limit=
128000/20000000 remote-address=pppoe-pool use-compression=default
add change-tcp-mss=default comment="" name="BLUE VPN" only-one=default
192.168.20.1 name="768/128 VPN" only-one=default rate-limit=128000/768000
192.168.10.1 name="4096/196 PPPoE" only-one=default rate-limit=
196000/4096000 remote-address=pppoe-pool use-compression=default
192.168.20.1 name="NOLIMIT VPN cap" only-one=default rate-limit=
128000/20000000 remote-address=vpn-pool use-compression=default
192.168.10.1 name="768/64 PPPoE" only-one=default rate-limit=64000/768000
192.168.10.1 name="128/64 PPPoE" only-one=default rate-limit=64000/128000
192.168.20.1 name="NO LIMIT VPN LAN" only-one=default remote-address=
lan-pool use-compression=default use-encryption=default
add change-tcp-mss=yes comment="" dns-server=192.168.20.1 idle-timeout=3m
local-address=192.168.20.1 name="192/192 VPN - s neta" only-one=default
rate-limit=192000/192000 remote-address=vpn-pool session-timeout=10m
use-compression=default use-encryption=required use-vj-compression=
default
192.168.10.1 name="1024/64 PPPoE" only-one=default rate-limit=
64000/1024000 remote-address=pppoe-pool use-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption
only-one=default use-compression=default use-encryption=yes
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/ppp secret
add caller-id="" comment="" disabled=no limit-bytes-in=0 limit-bytes-out=0
192.168.10.5 routes="" service=pppoe
192.168.20.254 routes="" service=pptp
remote-address=192.168.10.3 routes="" service=pppoe
192.168.10.17 routes="" service=pppoe
192.168.10.12 routes="" service=pppoe
192.168.20.253 routes="" service=pptp
On the new MT within the Winbox - default and default-encryption are colored blue. I guess it has something to do with it…?
edit: on new MT I did a config reset and used quick setup and entered data for home AP and selected PPPoE and it still wouldn’t connect. And even after resetting the router to the defaults, those two PPP rules are still blue colored.
I solved it, the problem was in ISP. So much trouble for nothing. I only had to copy MAC address from ADSL interface on old router to the same interface on new one.
As T-Com Croatia has a policy of only 1 MAC per user.
