PPPoE & Hotspot Server on the same interface with usermamager.
Hello friends, need expert advice on my setup. I want to create PPPoE & Hotspot Server with usermanager on the same interface on CCR1009 router. PPPoE clients will be manage via winbox locally but Hotspot Server will be maintained by usermanager. Is it safe to do that setup? There will be two different ip pools. One for Hotspot & the other for PPPoE Server. Is it okay with the setup? All of my 300client can use PPPoE or Hotspot whatever the like.
Please correct me if anything wrong.
Regards
Anyone please update me?
Sent from my iPhone using Tapatalk
Pppoe server and hotspot server on same interface is not a good practice. But if you have to do so ,use different vlans for both server.
Sent from my MI MAX using Tapatalk
Dear friend, is there any problem to do so?
Regards
This will create problem , I’ve tried once . Search forum for more information.
