Hi!.
This is the topology and network that i want to get working. But for some reason this is not posible. There is something that a am missing.
I am connecting succesfully with a pppoe in Area7 and all areas bellow the Switch 1. But if a put my patchcord in another RB2011 of the switch 2 the PPPoE is not working.
I have tested with changing the MTU without success.
The switches are IDENTICAL firmwares, and routeros version. Same packages updated to RouterOS 6.38.3, and transparency mode. (Only put the sfps like slaves of port sfp1).
And here the configuration of the core (1016) router:
//////////////// BRIDGE ////////////////////
[admin@CCR1016] > inter bridge export
# jan/02/2002 08:11:12 by RouterOS 6.38.3
add name=bridge-internet
add name=bridge-iptv
add name=lo_bridge
add bridge=bridge-internet horizon=1 interface=vlan72__internet
add bridge=bridge-iptv horizon=1 interface=vlan71__iptv
add bridge=bridge-iptv horizon=1 interface=vlan161__iptv
add bridge=bridge-internet horizon=1 interface=vlan162__internet
/////////////////////// IP ADDRESS /////////////////////////////
[admin@CCR1016] > ip address exp
# jan/02/2002 07:52:45 by RouterOS 6.38.3
add address=10.1.102.1/30 comment="FIBRA OPTiCA" interface=sfp5_fo_switch1 network=10.1.102.0
add address=10.1.103.1/30 interface=sfp5_fo_switch1 network=10.1.103.0
add address=10.1.104.1/30 interface=sfp5_fo_switch1 network=10.1.104.0
add address=10.1.105.1/30 interface=sfp5_fo_switch1 network=10.1.105.0
add address=10.1.106.1/30 interface=sfp5_fo_switch1 network=10.1.106.0
add address=10.1.107.1/30 interface=sfp5_fo_switch1 network=10.1.107.0
add address=10.1.108.1/30 interface=sfp5_fo_switch1 network=10.1.108.0
add address=10.1.109.1/30 interface=sfp5_fo_switch1 network=10.1.109.0
add address=10.1.110.1/30 interface=sfp5_fo_switch1 network=10.1.110.0
add address=10.1.112.1/30 interface=sfp6_fo_switch2 network=10.1.112.0
add address=10.1.113.1/30 interface=sfp6_fo_switch2 network=10.1.113.0
add address=10.1.114.1/30 interface=sfp6_fo_switch2 network=10.1.114.0
add address=10.1.115.1/30 interface=sfp6_fo_switch2 network=10.1.115.0
add address=10.1.116.1/30 interface=sfp6_fo_switch2 network=10.1.116.0
add address=10.1.117.1/30 interface=sfp6_fo_switch2 network=10.1.117.0
add address=10.1.118.1/30 interface=sfp6_fo_switch2 network=10.1.118.0
add address=10.1.119.1/30 interface=sfp6_fo_switch2 network=10.1.119.0
add address=10.255.255.254 interface=lo_bridge network=10.255.255.254
//////////////////// OSPF ///////////////////////
[admin@CCR1016] > routing ospf export
# jan/02/2002 07:50:36 by RouterOS 6.38.3
/routing ospf area
add area-id=0.0.0.1 disabled=yes name=area1
add area-id=0.0.0.7 name=area7
add area-id=0.0.0.13 name=area13
add area-id=0.0.0.17 name=area17
add area-id=0.0.0.9 name=area9
add area-id=0.0.0.2 name=area2
add area-id=0.0.0.3 name=area3
add area-id=0.0.0.4 name=area4
add area-id=0.0.0.5 name=area5
add area-id=0.0.0.6 name=area6
add area-id=0.0.0.8 name=area8
add area-id=0.0.0.10 name=area10
add area-id=0.0.0.11 name=area11
add area-id=0.0.0.12 name=area12
add area-id=0.0.0.14 name=area14
add area-id=0.0.0.15 name=area15
add area-id=0.0.0.16 name=area16
add area-id=0.0.0.18 name=area18
add area-id=0.0.0.19 name=area19
add area-id=0.0.0.20 name=area20
add area-id=0.0.0.21 name=area21
add area-id=0.0.0.22 name=area22
add area-id=0.0.0.23 name=area23
add area-id=0.0.0.24 name=area24
add area-id=0.0.0.25 name=area25
add area-id=0.0.0.26 name=area26
add area-id=0.0.0.27 name=area27
add area-id=0.0.0.28 name=area28
add area-id=0.0.0.29 name=area29
/routing ospf instance
set [ find default=yes ] comment="ip de loopback" name=MT-Server redistribute-connected=as-type-1 router-id=10.255.255.254
/routing ospf interface
add interface=sfp5_fo_switch1 network-type=ptmp
add interface=sfpp1_fo_switch3 network-type=ptmp
add interface=sfp6_fo_switch2 network-type=ptmp
/routing ospf network
add area=backbone disabled=yes network=10.100.100.0/27
add area=area7 network=10.1.107.0/30
add area=area2 network=10.1.102.0/30
add area=area3 network=10.1.103.0/30
add area=area4 network=10.1.104.0/30
add area=area5 network=10.1.105.0/30
add area=area6 network=10.1.106.0/30
add area=area8 network=10.1.108.0/30
add area=area9 network=10.1.109.0/30
add area=area10 network=10.1.110.0/30
add area=area11 network=10.1.111.0/30
add area=area12 network=10.1.112.0/30
add area=area13 network=10.1.113.0/30
add area=area14 network=10.1.114.0/30
add area=area15 network=10.1.115.0/30
add area=area16 network=10.1.116.0/30
add area=area17 network=10.1.117.0/30
add area=area18 network=10.1.118.0/30
add area=area19 network=10.1.119.0/30
add area=area20 network=10.1.120.0/30
add area=area21 network=10.1.121.0/30
add area=area22 network=10.1.122.0/30
add area=area23 network=10.1.123.0/30
add area=area24 network=10.1.124.0/30
add area=area25 network=10.1.125.0/30
add area=area26 network=10.1.126.0/30
add area=area27 network=10.1.127.0/30
add area=area28 network=10.1.128.0/30
add area=area29 network=10.1.129.0/30
/routing ospf virtual-link
add neighbor-id=10.255.255.16 transit-area=area16
add neighbor-id=10.255.255.7 transit-area=area7
////////////////////////////// MPLS //////////////////////////////
[admin@CCR1016] > mpls export
# jan/02/2002 08:08:33 by RouterOS 6.38.3
/mpls interface
set [ find default=yes ] mpls-mtu=1550
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=10.255.255.254 transport-address=10.255.255.254
/mpls ldp interface
//////////////// INTERFACE VPLS ///////////////////////////////
[admin@CCR1016] > interfa vpls expo
# jan/02/2002 08:05:55 by RouterOS 6.38.3
/interface vpls
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:48:3D:ED:E3:4B name=vpls_02_B1-PECO remote-peer=10.255.255.2 vpls-id=2:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:D9:89:BE:A1:F9 name=vpls_03_B1-COLOMBO remote-peer=10.255.255.3 vpls-id=3:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:0B:61:0D:56:22 name=vpls_04_B1 remote-peer=10.255.255.4 vpls-id=4:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:9D:84:61:D2:B5 name=vpls_05_B1-PLAZA remote-peer=10.255.255.5 vpls-id=5:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:FC:0D:72:21:0F name=vpls_06_B1-KITOVA remote-peer=10.255.255.6 vpls-id=6:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:28:3D:08:39:62 name=vpls_07_B1-SEIJAS-1 remote-peer=10.255.255.7 vpls-id=7:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:1E:A3:8D:74:19 name=vpls_07_B1-SEIJAS-2 remote-peer=10.255.255.7 vpls-id=7:2
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:A8:2C:81:4A:CC name=vpls_08_B1-PILETA remote-peer=10.255.255.8 vpls-id=8:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:91:6D:4E:26:17 name=vpls_09_B1-GONZALEZ remote-peer=10.255.255.9 vpls-id=9:1
add disabled=no l2mtu=1500 mac-address=00:2A:84:D3:64:E3 name=vpls_10_B1-SCHNEIDER remote-peer=10.255.255.10 vpls-id=10:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:75:34:2E:C0:96 name=vpls_11_B1-OSDE remote-peer=10.255.255.11 vpls-id=11:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:C9:77:E7:C3:62 name=vpls_12_B1-LUENGO remote-peer=10.255.255.12 vpls-id=12:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:4C:8E:4D:6D:BA name=vpls_13_B1-BLAT remote-peer=10.255.255.13 vpls-id=13:1
add disabled=no l2mtu=1500 mac-address=02:8A:E2:78:83:8B name=vpls_14_B1-MENDOZA remote-peer=10.255.255.14 vpls-id=14:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:C3:45:6D:ED:0A name=vpls_15_B1-MONI remote-peer=10.255.255.15 vpls-id=15:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:8D:CC:BC:B7:61 name=vpls_16_B1-1 remote-peer=10.255.255.16 vpls-id=16:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:71:77:D4:D6:D5 name=vpls_16_B1-2 remote-peer=10.255.255.16 vpls-id=16:2
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:B4:35:7C:38:15 name=vpls_17_B1-ESCUELA-60 remote-peer=10.255.255.17 vpls-id=17:1
add mac-address=02:AF:D4:56:62:D5 name=vpls_17_B1_slave remote-peer=10.255.253.17 vpls-id=17:4
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:9F:43:F5:50:00 name=vpls_18_B1 remote-peer=10.255.255.18 vpls-id=18:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:B3:01:1D:29:0F name=vpls_19_B1-CANINO remote-peer=10.255.255.19 vpls-id=19:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:E5:33:4A:0E:F8 name=vpls_20_B1-CONTENTEZ remote-peer=10.255.255.20 vpls-id=20:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:5B:77:71:08:EF name=vpls_21_B1-DARDO remote-peer=10.255.255.21 vpls-id=21:1
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:05:6A:B7:85:02 name=vpls_22_B1-POOL remote-peer=10.255.255.22 vpls-id=22:1
add advertised-l2mtu=1508 mac-address=02:F8:2E:95:6D:B6 name=vpls_22_B1-POOL-APDell remote-peer=10.255.255.22 vpls-id=22:3
add advertised-l2mtu=1508 mac-address=02:47:8A:19:38:83 name=vpls_22_B1-POOL-Rocket remote-peer=10.255.255.22 vpls-id=22:2
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:3D:D2:B8:32:5D name=vpls_23_B1-CALDEN remote-peer=10.255.255.23 vpls-id=23:1
add advertised-l2mtu=1508 mac-address=02:3D:D2:B8:32:5D name=vpls_23_B1-CALDEN-Nano remote-peer=10.255.255.23 vpls-id=23:2
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=02:35:C1:F3:1B:2C name=vpls_24_B1 remote-peer=10.255.255.24 vpls-id=24:1
////////////////// INTERFACE VLANS ///////////////////////////
/interface vlan
add interface=vpls_07_B1-SEIJAS-1 name=vlan71__iptv use-service-tag=yes vlan-id=71
add interface=vpls_07_B1-SEIJAS-2 name=vlan72__internet use-service-tag=yes vlan-id=72
add interface=vpls_16_B1-1 name=vlan161__iptv use-service-tag=yes vlan-id=161
add interface=vpls_16_B1-2 name=vlan162__internet vlan-id=162
I don’t have any more ideas to try. Some help will be apreciated.
