My problem is when I try to enable bandwidth control on the PPPoE Client it will drop the client when there is a large amount of Bandwith transfered. I have change my MTU to 1440 & 1492 still have the same problem when I don’t have the limit on it works fine.
Thanks,
Mike
I am currently running 2.8.28 software…
I also can’t take the MTU to 1492 when I set it at that the PPPoE Client still connects at 1480 not 1492 like I set it in the router. this is just a router I go though Engenious AP to a XP box with a Lucent NIC card installed for testing…
THANKS FOR ALL YOUR HELP!
Mike
I have my MTU set at 1460 and my MRU at 1440
Haven’t had any issues with these settings
