Hello Evreyone i have RB4011
ihave 150MB speed
Issues : when i connect the internet throw pppoe connectiuon i got 80-90 just ??
when i cponnect direct i got 150 ?
Fasttrack=Disable
MTU=1492
Firewall Rule = 0
ihave 150MB speed
Fasttrack=Disable
MTU=1492
Firewall Rule = 0
It’s normal to see a reduction in the internet speed when using a PPPoE connection, as the connection requires some overhead for the authentication process.
However, a reduction of 60-70 MBps is quite significant and there could be a few reasons for this. Here are some things you can try to troubleshoot the issue:
I hope this helps!
Thanks You alot
the proplem sloved
ISSUES : in the firewall managle rule of load balance in dst adress i just replace router ip 192.168.88.0/24 to the PPPOE IP POOL 192.168.200.0/24 and after that i got full speed
Thanks You alot
the proplem sloved
Yes, those rules were clearly broken in the config you’ve shown us in the first post.
Oh, wait..
