PPPoE Mikrotik
Hello.
If you insert the provider cable into the computer directly and configure a PPPoE connection, then everything works.
On Mikrotik PPPoE does not connect.
Login and password are correct.
Well, it works … I dare to claim that it works for lakhs of users … so you have to ask yourself why it doesn’t work for you. It is possible you mis-configured something.
