It seems like rule is not processed … but counter in mangle is counting packets … Basicly this works like if we have MSS correction disabled … so no rewrite in header and users have problems with opening pages from servers using MTU 1500 …
I’m not 100% if its due to the same “bug”…
I had to change my PPTP Client interface’s max MTU (from the default of 1460 to like 1400) that was connecting to a server via a PPPoE connection in ROS v3.30. I can’t remember that I’ve had to do that when the router was running ROS v4.5. I had the change TCP MSS left on default (enabled) in both versions.
