My follow are problem:
Given one Main Server and it made to call routing and pppoe. The Users to connection for the net through the Wlan interface. It’s in ap.-s rb 532 and cm9 cards. I have some Users, where I have some interesting problem: the pppoe connection is come into being for server and it has data traffic, but after little time eliminate the data traffic for invisible cause, but connection exist and not split it. In this case, that I have data traffic, I should to reconnection the pppoe cliens for server. Interesting thing, that come in the failure between the different signal levels. It has where 59 dB the signal level and it has where 79 dB, so occuring the failure. The pppoe connection has encrypting mppe 128 bit.MTU:1972 -
The next problem: Practically I have adjusted, that one login/pass pair to connection up more time for the server and different IP to divide out from the range, but then I haven’t knew to catch, that 2 active connection has one in login/pass and than dividing in band (512/512) and not both connection 512/512 to divide the server.
Thank for your help in advance and have anice day!
