I recently bought a HEX router. I have a fibre connection at home (Freedom internet in The Netherlands), which uses PPPoE over VLAN 6. The HEX router should act as a PPPoE client and deliver the internet signal without NAT on one of the ports so I can put my Unifi UXG router behind it, because it doesn’t handle PPPoE very well.
I’ve set up the PPPoE client but I’m a but confused how I deliver the internet signal to port 5 on the HEX router. Could someone explain to me how to set this up?
My current configuration is:
# 2024-06-21 23:49:28 by RouterOS 7.15.1
# software id = 8W19-104L
# model = RB750Gr3
# serial number = HG409Y9KGW4
add admin-mac=D4:01:C3:2B:76:1F auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface vlan
add interface=ether1 mtu=1508 name=bridge-WAN vlan-id=6
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=bridge-WAN max-mru=1500 max-mtu=1500 name=pppoe-client service-name="Freedom Internet" use-peer-dns=yes user=fake@freedom.nl
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Amsterdam
/system note
set show-at-login=no
/system routerboard settings
set silent-boot=yes
/tool mac-server
/tool mac-server mac-winbox
