I’m still trying to wrap my head around migrating over to PPPoE from DHCP.
At the tower location, I want to have a Mikrotik 3011 with a PPPoE interface on a port. Connected to this port via ethernet would be a RocketM365 which would have subscribers connected from their respective CPEs. I understand getting the SMs setup to authenticate using PPPoE and then I’m going to NAT the LAN side so the customer has no layer 2 connection to my network. The area I’m not to sure about yet is how I’m going to be able to access the access point on the management interface. The access point only has Static or DHCP on the management interface for options, so if I have that port on a PPPoE interface, there would be no IP address on the PPPoE interface so how am I supposed to access the access point remotely?
