pppoe on bridge, upload limit not works
I am running pppoe on bridge, i have also usermanager, and upload limits not working,i meen client are limmited with download speed but not upload, i think this is bug,
Make sure you have enabled,
interface bridge settings set use-ip-firewall-for-pppoe=yes
Hello
Of course this check box is checked but it not working anyway
What is your configuration for /queue ? (Simple or tree, which of them you are using).
I am using radius and queues are created automaticaly
Hi Sergejs, i had this problem of upload limit on RoS 5.18 with pppoe-server on bridge interface and solved all “disabling” use-ip-firewall on bridge settings…
I don´t know why! but disabling the use-ip-firewall, the advanced QoS are more efficient marking packets in mangle and the limit of each pppoe client in queues simple is perfect…
Regards!
i found solution
just go bridge setting use IP firewall= no
