Hi m8’s!
I’m using ospf in my network and pppoe with radius authentication. Now I need to use a RB411 with 3 pppoe users. It works well till one pppoe session is initiated. after the second client trying to connect from the same RB411 the first session stops working (ping timeout), and then they alternate. what could be wrong? what should i set to work well? but on the same AP i have a ubiquiti NSM5 with two ethernet ports, works fine.
BR.
