PPPoe Over Wireless
Does PPPoE work over the wireless?
Of course it does.
yes, you can do it…
our pppoe and control them with userman as centralize for AAA over wire and unwire for far..far..far ways
regards
Hasbullah.com
Yes
Yes, it does, I am have a site that is running PPPoE over Wireless (2.4GHz and 5.7GHz) :slight_smile:
For sure!
We had to use a lower MTU for better session stability, we ended up at 1460 after much testing
Hi Freman,
is 1460 a value obtained considering project parameters?
I’m looking for a guideline in order to understand how better configure MTU parameters. Is it influenced by the number of wireless links between PPPoE concentrator and CPE? :confused:
I’m using MK as PPPoE concentrator and OSBridge 5Xli (http://www.osbridge.com) as CPEs at customer’s site.
Rgds
We simply pinged with large packets starting at 1500 working down till they were being delivered consistently
