PPPoE over wireless
Hi all,
are ther docs around give guidlines for PPPoE over wireless? This is reserving me unwanted surprises…
I’m using MT as Access Concentrator and OSBridge as CPE with embedded PPPoE client. Everithing works fine but suddenly some web sites didn’t work any more for some customers. The strange thing is that some Customers have this problem and others do no have it, inside the same network cell, the same access concentrator and wiht the same firmware version on CPEs… ???
Using PPPoE authentication on Windows client instead of CPE solve the problem, but MTU/MRU negotiated by M$ client is the same used by CPE, so nothing should have changed… ???
Make sure that you have decreased MTU/MRU for PPPoE server configuration, and change-tcp-mss=yes is used.
Thank you sergejs,
setting “change-tcp-mss=yes” solved the problem.
It is strange, because with “change-tcp-mss=no” it worked fine for weeks and, suddenly, it crashed… is there a reason for this?
rgds
It’s working wery well, I set “keepalive timeout” to 20 (default is 10 and I thing is very good to ethernet not for wireless)
