PPPOE passthrough without using WDS
Is there any way to do a pppoe passthrough to my tower.
I basically want to connect a 411 cpe connected to my hi-site which has the nas setup.
I want to create multiple pppoe within the ethernet port for different applications. Dont want to use NAT for some of the apps as one of them is VOIP.
I tried using staion-psuedobridge. didnt work well.
you can create eoip tunnels
