I have mikrotik 951g routerbord with hotspot server and radius server configured. My problem is that when I setup the pppoe server with the radius server the pppoe and hotspot clients connect successfully. However ,after a period of time the pppoe client and the hotspot client can not be authenticated by the radius server and get the message says "Radius Server is not responding " with the hotspot clients and the pppoe clients can not connect again. I don’t know where is the problem is it with the routerboard model ,the pppoe server settings or the radius server ???
/system logging add topics=radius
/log print follow-only where topics~“radius”
Then try to connect a client and see whether there is a corresponding radius message in the log. The subsequent steps depend on whether you use the embedded RADIUS server of Mikrotik (user manager) or an external RADIUS server as I assume.
Thank you for your fast reply sindy. I’ll try it and see the results in the log. I’m using the embedded radius server of the Mikrotik.
These are the messages from the log :
this is for the pppoe user
11:05:28 radius,debug,packet sending Access-Request with id 203 to 127.0.0.1:1812
11:05:28 radius,debug,packet Signature = 0xdf70e93e8e6e5832e3b1bd81023ad2ec
11:05:28 radius,debug,packet Service-Type = 2
11:05:28 radius,debug,packet Framed-Protocol = 1
11:05:28 radius,debug,packet NAS-Port = 15728700
11:05:28 radius,debug,packet NAS-Port-Type = 15
11:05:28 radius,debug,packet User-Name = "ppp2"
11:05:28 radius,debug,packet Calling-Station-Id = "CC:2D:E0:F8:49:F0"
11:05:28 radius,debug,packet Called-Station-Id = "service1"
11:05:28 radius,debug,packet NAS-Port-Id = "ether5"
11:05:28 radius,debug,packet Acct-Session-Id = "8120003a"
11:05:28 radius,debug,packet MS-CHAP-Challenge = 0x05947c4143589abc446a95dfece7fc7f
11:05:28 radius,debug,packet MS-CHAP2-Response = 0x0100894811b2faff4c46429ec8fdcd25
11:05:28 radius,debug,packet edc900000000000000000e6b20ab7fd5
11:05:28 radius,debug,packet 013ec705260fd92c8418bb5568a10e1e
11:05:28 radius,debug,packet 1511
11:05:28 radius,debug,packet NAS-Identifier = "HOTspot Server"
11:05:28 radius,debug,packet NAS-IP-Address = 127.0.0.1
11:05:28 radius,debug timeout for 1b:4d
this one is for the hotspot user witch couldn’t sign in too
11:11:23 radius,debug,packet sending Access-Request with id 236 to 127.0.0.1:1812
11:11:23 radius,debug,packet Signature = 0xd7c957083352249716220ba92a36226d
11:11:23 radius,debug,packet NAS-Port-Type = 19
11:11:23 radius,debug,packet Calling-Station-Id = "D4:53:83:79:4E:DF"
11:11:23 radius,debug,packet Called-Station-Id = "hs-wlan1"
11:11:23 radius,debug,packet NAS-Port-Id = "wlan1"
11:11:23 radius,debug,packet User-Name = "mmhh"
11:11:23 radius,debug,packet NAS-Port = 2162163737
11:11:23 radius,debug,packet Acct-Session-Id = "80e00019"
11:11:23 radius,debug,packet Framed-IP-Address = 192.168.50.250
11:11:23 radius,debug,packet MT-Host-IP = 192.168.50.250
11:11:23 radius,debug,packet CHAP-Challenge = 0xced5c597b1e2d707346ea94be80d83a8
11:11:23 radius,debug,packet CHAP-Password = 0x1d2f3dc6be93722d05c8ce97d2254bf5
11:11:23 radius,debug,packet 38
11:11:23 radius,debug,packet Service-Type = 1
11:11:23 radius,debug,packet WISPr-Logoff-URL = "http://192.168.50.1/logout"
11:11:23 radius,debug,packet NAS-Identifier = "HOTspot Server"
11:11:23 radius,debug,packet NAS-IP-Address = 127.0.0.1
11:11:23 radius,debug timeout for 1b:6d
11:11:23 radius,debug timeout for 3f:bb
they both keep trying but can’t connect
OK, so it may be a firewall issue (not much likely, but possible), or the networking stack is broken (even less likely), or the UserManager stopped responding. Since /tool sniffer doesn’t seem to work on the loopback interface, you have to use alternative means: what does /ip firewall connection print interval=1 where dst-address~“:1812” show during these unsuccesful attempts to connect?
This is the output of the /ip firewall connection print interval=1 where dst-address~“:1812” command :
# PR.. SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT ORIG-RATE REPL-RATE ORIG-PACKETS REPL-PACKETS
27 C s udp 127.0.0.1:35747 127.0.0.1:1812 9s 0bps 0bps 3 0
What is surprising here is the s (src-nat) indicator in the connection attributes. So try /ip firewall connection print detail where dst-address~“:1812” and see what the reply-dst-address is.
Then, use /ip route check that.ip.add.ress to see whether there is a route to that address. If my assumption is correct, the User Manager process is unable to send the response, because either a route to that address doesn’t exist, or it is a dynamically added route as the address is in a connected subnet but doesn’t respond to ARP requests.
In any case, post the export of your configuration - there must be some action=srcnat or action=masquerade rule, which is not selective enough and causes the internal RADIUS requests to be src-nated.
the output of the /ip firewall connection print detail where dst-address~“:1812” command:
Flags: E - expected, S - seen-reply, A - assured, C - confirmed, D - dying, F - fasttrack, s - srcnat, d - dstnat
0 S C protocol=udp src-address=127.0.0.1:37012 dst-address=127.0.0.1:1812 reply-src-address=127.0.0.1:1812
reply-dst-address=127.0.0.1:37012 timeout=0s orig-packets=1 orig-bytes=229 orig-fasttrack-packets=0 orig-fasttrack-bytes=0
repl-packets=1 repl-bytes=219 repl-fasttrack-packets=0 repl-fasttrack-bytes=0 orig-rate=0bps repl-rate=0bps
this is the nat configuration on the pppoe server side :
0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
1 D chain=hotspot action=jump jump-target=pre-hotspot
2 D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
3 D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
4 D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
5 D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
6 D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
7 D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
8 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp in-interface=vlan20 dst-port=443
9 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp in-interface=vlan30 dst-port=443
10 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
11 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
12 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
13 D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
14 D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
15 D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
16 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
17 chain=srcnat action=masquerade src-address=192.168.95.0/24 out-interface=pppoe-out1 log=no log-prefix=""
18 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.50.0/24
19 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.10.0/24
20 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.20.0/24
21 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.30.0/24
22 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp in-interface=wlan1 dst-port=443
On the pppoe client side I’ve noticed that there is a nat configured like this
NOTE:there is not route to the 172.0.0.1 in the routing table on both sides
This one with detail shows the connection when the RADIUS server does respond, so it is unusable for the analysis.
In this one, the S is an upper-case (capital) one, indicating seen-reply, whereas in the previous case, it was a lower-case one, indicating srcnat.
So you need to run the command with detail during the time when the RADIUS process does not respond.
A route to 127.0.0.0/8 is not shown in the configuration as this whole range are addresses representing the device itself and packets to them cannot be sent out.
I cannot see any rule on the PPPoE server/RADIUS client & RADIUS server that would explain why the connection from the RADIUS client to the RADIUS server gets src-nat’ed, unless the client sends the request from one of the addresses to which the srcnat rules refer, or unless some srcnat rule is created dynamically (I’ve got no idea so far why and how it should be) and causes this.
So wait until the problem appears again, and only then print again the current contents of the /ip firewall nat table and run the /ip firewall connection print detail … as above.
The configuration of the PPPoE client is irrelevant here. It’s the PPPoE server that uses the local RADIUS client to ask the local RADIUS server.
But the fact that the masquerade rule at the client matches on all interfaces may cause some issues to the client, unrelated to the authentication problem with RADIUS.
I think the problem has been solved sindy. the problem was with the NAT on both sides, after I removed the NAT on the pppoe client side
and edit the NAT on the server side as following
now all the pppoe clients connect normally and won’t disconnect
I don’t know how to thank you siday. every time i have a problem you help me, thank you
